Question about Brother IntelliFAX 2800 Laser Fax
Poor Line Connection
I am unable to fax to 804 area codes. The fax on the other end will pickup and screech, then our fax will start sending and then stop in the middle and Communication Error. I have noticed this only happens on 804 area codes. I am dialing from 276 area code. Any suggestions?
  • Anonymous Oct 27, 2008
    I have this same problem, but my problem is limited to as far as I know 2 locations. One is in California, the other Des Moines Iowa. I recieve the same error on those 2 locations, but on none of the other 30+ places I fax things to. I send one page, then I get Comm error 20, the other fax machine also recieves the same error on their end.
    It is not tied to phone lines I have tried multiple phone lines, and Its not their machine because other locations can fax to them just fine. Its something internal to the machine itself.
    Problem Solver:
  • 12 Answers
If the fax works in all other instances other than when you dial a certain area code I would say the problem is definately not associated with the machine itself. I have never heard of this type of problem. I would contact your phone company and tell them your situation and see if they have any advice from their end.
Posted on Mar 28, 2008
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
Cannon Fax Machine Super G3 Unable to send. Phone rings but does not send. No error message.
In order to send, the recieving machine and the sending machine need to handshake (agree on setting, etc.)
If, as your description says the phone is ringing, I presume your are the sender.....what you need to hear is the other machine pick up, and then fax screech noises..... Test by calling the receiving fax by regular phone, and you should hear a pickup and fax noises....if not, your machine would never send.
Mar 26, 2011 | Computers & Internet
My 575 fax won't send; it keeps printing "poor line condition". Is there something I can do? I am just trying to send a fax like I always do. It makes the noise at first like it does when it transmits,...
If this is happening to only one number you're trying to fax to, then the problem is most likely on their end, not yours. If it is happening with all the numbers you fax to, then I would suggest checking the telephone line hooked to the fax. Look for loose connections, or perhaps a bad cord from the phone outlet. The connection could be good enough to get a dial tone, but not secure enough for the fax to operate. If none of that holds true, I would suggest taking it to the shop and let a technician look it over.
Oct 23, 2010 | Brother FAX-575 Plain Paper Thermal
What does poor line condition mean/ is it my line or the person I am sending to
It could be either or but normally its the connection.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack.
Jun 16, 2010 | Brother IntelliFAX 4100 Laser Fax
Error code 48
Code 48 is internet disconnect.
On the machine if the machine is set up for internet connection, turn it off. Sometimes email is turned on and the other settings are not setup correctly.
Make sure all settings are done correctly
If one is faxing make sure the phone line is connected correctly and their is a good sounding dial tone.
One area to keep in mind is a phone dial tone turning off and on.This can be a phone company issue or poor line connectors in the building, even a corroded plug on the phone receptical.
Check these areas, even replace the phone line cord with a new one.
On the machine a fax machine not sending or recieivng, suspect a board causing the problem.
Jun 08, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Fax won't send
try sending a fax using your fax on another telephone line because your phone line might be faulty.also try sending to different fax numbers to see if it` is your fax which has a problem or the other
Aug 21, 2009 | Panasonic KX-FP121 Plain Paper Thermal Fax
''poor line connection''
THEY probably have their fax hooked to a DIGITAL phone line.
Aug 20, 2009 | Office Equipment & Supplies
Unable to send fax
press *99 before the number it will work
Aug 09, 2009 | Brother FAX-575 Plain Paper Thermal
Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
Mar 19, 2009 | Brother MFC-9440CN Laser Printer
Can't fax long distance now-
Do you have a DIGITAL phone service like Vonage?
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line..
Dec 17, 2008 | HP Officejet 5510 All-In-One Thermal...
Brother IntelliFAX 2800 Laser Fax Logo
418 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
