Re: starter clicks when trying to crank...now nothing.
Check your battery cable running to your stater solenoid and to the starter, check the connections good. Also check you ground wire for good connection
Please provide with more detail. Does it make a click sound when turning the ignition? Does it crank?
Have you tried to jump the battery with jumping cable or tried it on a know good batteries?
- If the car does make a cranking noised then the starter is good but weak battery.
- If there is no noise or clicking, then dead battery.
- If you can hear the clicking when turning the key to start, then check for battery GROUND.
- If battery were tested and it read 12.5 - 14.0 DCV. Then your starter are bad.
There also other thing to check like security alarm system with ignition switch kill... But most common problems with fail to start are mention above.
Hello! Do you hear a click when the key is turned?...If no click is heard either the ignition key, the Crank relay, the starter, or the battery are suspect...Having lights and radio does not mean the battery is capable of running a starter motor......Put a meter on the battery...should read 12.5 volts...Turn key...Does voltage drop to 8 or 9 volts? Bad battery...If all is well with battery and connections to it...Check the starter fuse # 33 in the under hood fuse/relay box...If the fuse is good that click you should hear is from the Crank Relay in that box...If all of the above is OK connect your meter to the Purple wire that is connected to the starter motor...When the key is turned 12 volts must be on that wire...If there is the starter motor is defective...So, #1...Do you hear a click when key is turned...That would point at a bad starter or weak battery...#2...If you do not hear a click bad fuse #33, bad Crank Relay, bad ignition switch...#3...If fuse is good Bad Crank Relay or Ignition switch; Crank Relay is a low cost item ($10)...Replace Relay...Stop there and send a comment as to results...Guru...saailer
Hi:) That sound like the solenoid is the problem it is located on the starter and if the solenoid is not working right it will do all the things you are explaining.And yes heat has alot to do with it and being ware out.If it is the original it is time to replace the starter anyways it's 16 years old.
Hi. Since starter and ignition switch has been change. Try looking at the battery and its physical connections. What i am seeing here is, there is no power going to the ignition to kick the starter. I provided you a link what needs to be checked for no starting issues. Please click here.
check your starter relay in the power distribution center. if you are not getting any crank. with a test light or dvom you can check the small signal wire on your starter solenoid when the key is in the crank position there should be power on this wire. it sounds like you are not getting signal to the starter from the ignition switch
it is most likley starter relay or starter.with vehicle in park and e-brake on have someone tap on the starter with hammer while your trying to start.if starter starts to crank then you know the starter is on the way out.if starter does not crank it may already be shot.srarter relay is on fire wall check power + ground.
