I have a Kenmore Dishwasher Model #587.14439200. I have just replaced the lower impeller but now when I try to run the machine it won't fill with water although it did before I replaced the impeller. the float is not stuck in any way.
first check to make sure the water is on then take the kick panel off and make sure the float is engaging the safety switch and the valve is plugged up if all that's ok check to si if the mircosafety switch is good
hi, i bought a second hand beko de3430FW dishwasher and there is a problem with a transistor on the...
(More)
hi, i bought a second hand beko de3430FW dishwasher and there is a problem with a transistor on the switchboard (i'm not sure if you understand but i can send you pictures)
just stopped on previous wash and tripped electrics. left it for a while and tried again it...
(More)
just stopped on previous wash and tripped electrics. left it for a while and tried again it continued its cycle. when i went to it, it hadn't completed its cycle. now the start button is continually flashing when turned on
