Question about Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television
Under counter audiovox tv
There is a CD stuck in the player. When we first put it up I tried a DVD and it worked. I then put in a CD and it will not eject.. help!
    Sergeant:
  • 280 Answers
You can try to unplug it then plug it in and try eject. If that don't work the it will have to be disasembled to remove the disk. it could be that the disk is not spinning up and in that case it will have to be repaired
Posted on Apr 18, 2008
Just got the Coby 10.2 inch under counter tv with dvd out of the box. The TV works find but I can't get the dvd to work. It just keeps saying "No disk"
tried to load a dvd lens cleaner first in your dvd player, to remove dirt and sticky part of the cd.if still no disk, at this time you will need to check the dvd tray and assembly which the spindle motor not rotating.
Dec 25, 2012 | Coby KTF-DVD1093 10 in. Under Cabinet TV
We have an audiovox 15" Flat Panel LCD TV with built-in DVD player (Model # FPE1507DV) and the DVD player doesnt work at all. What do we do since they no longer make these TV sets? Who can repair or...
About your only option is to try and find a used replacement drive, try ShopJimmy.com and also search for your tv's model number on their and eBay, if your really lucky you might find a working pulled drive from another TV, but otherwise your pretty much stuck, there just isn't parts available other then other used ones to replace it. I get a lot of tv's in for repair with dead built in DVD players, i always recommend now to get a separate DVD player as the built in ones never last and when they die they are just dead. You could get a cheap dvd player and hook it up and use that instead, but your options of fixing the internal one are pretty limited.
Jan 02, 2018 | Audiovox FPE1507 15 in. LCD Television
My daughter has an Audiovox D1998 model and isn't reading the disc. where can I go to have this fixed and what would be the approximate cost?
Try a CD disc lens cleaner (can be found at Radio Shack, Wal Mart, Best Buy). Is it still under warranty? If not try your local TV repair shop for an estimate. But beware most shops do charge a diagnostic fee to look at the equipment. Note: Since these units can be found on the net for about $100 you may come out better with getting a new one.
Oct 21, 2009 | Audiovox D1812 Portable DVD Player
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Need a remote that works for TV and DVD player
Go to Remotes.com and put your model # in, they do have the original for $30.00
Feb 26, 2009 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Audiovox D1708
Look for dust, dirt or foreign object on the laser lens under where you put the disc in. Maybe blow some clean air on it.
Feb 27, 2007 | Audiovox D1708 Portable DVD Player
Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD TV WITH DVD&SPEAKERPHONE Television Logo
148 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
