Question about Thermador Ovens
Thermador built-in double wall oven -- replace cooling fan?
We have a 16 yr old Thermador CT 230 double wall oven (220v). Recently we went to bake something and neither oven would heat up. We called a local authorized repair person, who pulled the oven out of the wall (using an oven dolly), dismanted the cooling vent stack, and reached his arm in and physically turned the cooling fan. As soon as he did this, the fan worked, and the heating elements began to heat. At that point, the repair person declared that the fan, motor, and airflow switch would need to be replaced because they were probably "gummed" up, and couldn't be cleaned. He estimated the total cost would be nearly $600. Feeling helpless, we told him to go ahead. The parts are on order at this time. However, since he manually freed the cooling fan, the oven continues to operate normally. We now realize that he didn't even pull the protective covers off to see if in fact the fan was really dirty beyond the point of cleaning. So now we have several questions: 1) Should he have tried to fully examine the fan to see if it was too dirty to try to clean it? 2) Is it even a smart move to invest $600 in a 16 yr old oven even though an equivalent replacement is over $3,000? 3) We watched pretty carefully and know we could gain access to the controls and electronics just as the repair person did, should we try to simply clean this fan ourselves if fails again? We'd really appreciate your advice.
No, do not try it yourself. When the motor is bad sometimes it won't have the power to start itself. With a push it will take off. If you try to remove it yourself you will risk damaging cabinet, the oven itself, floors and/or yourself. Please trust your repairman. We are trained and experienced. Not everyone Is out to get you!
Posted on Sep 07, 2011
C302U Double Oven cooling fans shut off immediately after finishing bake cycle. Replaced control board, still does the same. What controls the cooling fans to protect the circuitry?
Newer versions of the control board software will run the cooling fans for a bit after the cycle ends, but many older models work like yours does
Aug 30, 2016 | Thermador C302U Electric Double Oven
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
I have a Thermador Model C302U wall oven the fan on the uppper oven starts and then stops and I get the F34 code I am thinking to replace the motor but I want to know if there are other things I should...
When that fan starts up the air pushes against an air switch and that tells the board the fan is blowing. The stove uses a DAC system that relies on switchs to confirm the operations of the fan. the DAC control uses signal voltage to detect switch function. The air switches must physically close by air movement from the cooling blowers before the oven proceeds into a bake or broil mode. Reason being f the cooling motor does not function and the oven goes into a bake or broil mode, the oven will overheat and could damage the fancy smancy over engineered piece of garbage electronic components. My opinion. This is not for the DIY unless you are a TV repairman.
Nov 03, 2011 | Thermador C302U Electric Double Oven
My thermador double oven does not turn off for 30 minutes.
Welcome to FixYa.
Please clarify if I`ve misunderstood what you`re asking, but with all Thermador ranges and wall ovens ( including your SC302T model, most brands in fact ) the cooling fans will remain on for quite some time after actually shutting the oven off.
This is done by design to keep the electronics cooled to a temperature usually below 200°F so they aren`t damaged.
Heat after all is the thing which damages electronics more than anything else.
I do have use and care guides available via email attachments in "pdf" if you need one.
Thank you for choosing FixYa. I hope this eases your concern. Please let me know.
Regards,
Macmarkus :)
Sep 07, 2010 | Thermador SC302T Electric Double Oven
Wall Oven JKP30W0M1WW - front control panel overlay bubbles and separates. It did this before it was 1 yr old and they sent me a replacement and now before that part is 1 yr old it is doing it again -...
GE is now fixing this problem, no charge. I called about mine, at 866-622-6184 They have the white version already available. A month wait on the black. Then they send out a service tech to install, free to you.
Jul 20, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Ovens Logo
646 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
