Question about Toshiba Satellite M65-S809 Notebook
Power plugin in back of m65
I broke the plug (inside)for the power where the adapter fits in back of computer. what is the name of that part ? can it be replaced?
  • mandih Feb 13, 2008
    thanks so much,
    amanda
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
The part is the AC power pin. . . .Look here for a replacement. The repair isn't as hard as some would have you think. The key to doing it successfully is to take it slow and EZ. Take digital pix of the dis-assembly process (use them later when re-assembling the system). Look online and you should be able to find a guide to dis-assembling your laptop. I've done a few and they really aren't that difficult. Parts are under ten bucks. Plan on about two or three hours to do the whole job.
Posted on Apr 25, 2008
  • 145 Answers
In laptops they consider it the power supply, because they usually replace the whole unit, you can probably find a new pin, just the broken one, at an electronics store such as Radio Shack/ Source by Cirquit City, and solder it to the board. Be aware it is quite difficult servicing a laptop and if you are not adept at electrical service you may severely damage the unit, in this case I would take it to a service shop.
Posted on Feb 11, 2008
My fire stick wont fit my lap top how can i make it work
These plugins are a pain in the back side to plugin, they will only fit one way! Look at them close and you will see what I mean? If it still wont fit they sell adapters on Amazon like the one in link below!
Amazon com C2G Cables to Go 52119 6 inch USB 2 0 Male to Female Extension...
Jul 14, 2017 | Top Computers & Internet
Broke power plug plugin boaed
Take it to a repair shop. You will never get a replacement board for this.
Apr 13, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
How is the power to the monitor supplied? via the computer or via an electrcally plug - I don't see were the connection is on the monitor
The monitor should have come with two cords. One the power cable which will have an electrical plug on one end that is plugged into a wall jack and the other should be one like this.The other end of the electrical plug should plugin somewhere on the bottom of the monitor.
There is another cable that looks like this which is known as a vga cable. Your monitor may take a DVI connector which has a white end and is a larger plug. This will plugin to the monitor and will also plugin to your computer. The place it plugs into the monitor should also be on the bottom of the monitor.
These cables will only fit in one way so you really can't mess anything up. Also the cable between the monitor and the tower are interchangeable it doesn't matter which side you plugin either way will work.
Apr 07, 2011 | KDS K-726MWB Monitor
It won't turn on
Hi. Try theses simple steps:
Remove the Battery
Remove the AC Adapter
Press/hold down power button for 10 seconds
Plug AC Adapter in and turn the computer on
If the system doesn't turn on still then there's a problem with your motherboard. and it might need replacement.
Jun 06, 2010 | IBM ThinkPad T40 2373 Notebook
I left my laptop turned on in my office when i came back then next morning it wont start even if I push the power button. The laptop was turned on when i left it.
Try to perform power drain. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in then plugin the power adapter then trn on the computer. You can also power on the computer without the battery. If your computer wont turn just using the power adapter then there is a possiblility that there is a problem with your power adapter.
May 19, 2010 | Computers & Internet
Were do i plugin my cable to my computer
For the safety and security you need to plugin your USB cable at the back part of your computer. Plugin it to the USB port,
Mar 03, 2010 | Microsoft Wireless Network Adapter Xbox...
Ac adapter light is solid green, but when plugged into laptop...
the most likely reason is a systemboard problem (the ac plugin port cannot changed independently for notebooks)
Mar 23, 2009 | Toshiba Satellite A65-S126 Notebook
Will not turn on, no lights at all
Try to remove the battery, and plug it into the wall. If it then boots, your battery has failed. This happens frequently. If it still wont boot you will need to take to someone to see if the board has died or other issues. Hope this helps
Nov 30, 2008 | Toshiba Satellite M65-S9063 PC Notebook
Computer recharger
To my knowledge most current laptop AC adapter are designated/designed to be autovolt. This refers to the capability of the adapter to accept (without any problem) any voltage anywhere and still process it to a useful output that the laptop can use. This could be verified by looking over the sticker/nameplate of the adapter. If it says 1--~240VAC, then it is auto volt. The next area of concern would be the way the AC plugs are designed. US standards differs from European and for the AC adapter/charger to fit the European wall outlets, some sort of mechanical adapter is required. Most US AC plugs are parallel polarized flat prongs whereas Europeans would be small circular prongs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 04, 2008 | Computers & Internet
Toshiba Satellite M65-S809 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
