Brother copier the corners of the pages being copied are folding over
  • pjmaddy Feb 12, 2008
    brother model #dcp 8065 dn laser
    Scholar:
  • 78 Answers
Whats the model? Inkjet or laser?
Posted on Feb 12, 2008
  • Clint Bowden
    Clint Bowden Feb 12, 2008
    It could be many things in this model.
    Check the paper guides in the tray. If they are loose the paper could skew and cause the paper to fold over or damage on the edge.
    Check for obstructios a piece of paper for example where the paper exits the tray or where it exits the fuser (hot section at the rear) are the most likely.
Brother mfc j533ddw top feeder sends documents through crooked. Sometimes folds over top corner of first page of document.
Use a bright light source and examine the paper path. There may be a scrap of paper or some obstruction causing foldover.
May 19, 2018 | Brother Office Equipment & Supplies
Brother MFC-8480DN Printer jammming
try to clean the document feeder, i think there so many scratch of small piece of paper that why the printer is paper jam.
Feb 07, 2014 | Brother MFC 7840W Printer
Do I load the original for faxing right side up or upside down? HP officejet v40
Look at the input tray it shows a symbol of an original.
If the lines on the symbol face you , then put the paper in face UP.
If the lines are on the folded corner of the symbol, then place the paper in face DOWN.
If you are still not sure, place the paper in face UP and press "COPY"
If it copies the page, then that is the correct orientation.
If thre copy is blank, repeat the copy test with the document face DOWN.
Sep 28, 2009 | HP Office Equipment & Supplies
Faxing up or down
Look at the hopper. It will almost certainly have a little graphic on it to tell you which way up the document goes.
If it looks like a sheet of paper with lines of writing on, the paper goes in print side up.
If it looks like a sheet of paper with one corner folded over, and lines of writing visible only on the turned over corner, then it goes in print side down.
If you can't find the graphic, then experiment: Take a blank sheet of paper. Write "Up" on one side and "Down" on the other then stick it into the machine so the writing is telling the truth. Most fax machines have a copy mode - use this to see which side of the paper the machine reads (if you can't get it to copy, fax your page to somebody and get them to phone back to tell you which side of the page they've received).
A.
Jan 18, 2009 | Brother Office Equipment & Supplies
Crooked Cpoies
Pull all of the paper out of paper tray and reload. More than likely you will find some sheets on the bottom that are folded at the corners. This will cause crooked copies and also jams.
Jan 14, 2009 | Office Equipment & Supplies
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
Corners folding while copying
if it is just folding the paper back without pressing it, then its a problem in the fuser. Paper sticking to long to the upper fuser roller and catching either a pick off finger or a mylar on the exit of the fuser.
Hope that helps...
Jun 17, 2008 | Ricoh Aficio 1035 Copier
Trouble Shoot for Printing HP Printer
the problem is with the sleeve that inside the fuzer unit.
it may shredded.. you cant solve the problem by your self.
thanks
Feb 22, 2008 | HP LaserJet 1020 Printer
Bell & Howell Copiscan Spectrum corner problems
It can be a nightmare to find out what is causing the dog ear page or folded page at the corner. Check your glass **** inside the scanner to make sure its seated in the scanner properly. The big one is the check the metal paper guides in the scanner paper path. If a guide is bend it will hook the paper and cause it to fold over.
Oct 15, 2007 | Bell & Howell B we Bell & Howell Spectrum...
My paper keeps "kinking"
Check the fusing unit.Pressure roller,pressure roller bushings, thermistors for over heating,fuser roller. replace if defective.
Sep 21, 2007 | Toshiba 1370 Black and White Copier
20 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
