Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Convergence Problem, need to replace the PC board
I had similar convergence problems on my Panasonic PT-53WX53 as many have posted here. Without previous experience, I attempted to replace the broken IC chips on the main board. Unfortunately I pulled off several tiny pieces of the circuit coating when I tried to remove the IC pins from the board. I would assume that I have damaged the main PC board and need to replace it (very expensive at $280). However, I am not sure how to disconnect the high power cable from the board, and how to disconnect this main board from the board connected through three connectors. Can someone help me? I would greatly appreciate!
    President:
  • 4,402 Answers
Hi!
see this site
Picture Tube Discharge First of all, If you don't have any technical training, I advise you to take it to a shop for repair, but the old way to discharge the tube is to take a long screwdriver, connect an aligator clip from the steel shaft to ground on the chassis, then making sure you hold the plastic handle of the screwdriver only, slide the end of the screwdriver under the suction cup on the tube, you will feel it hit a metal clip, and if it is still charged, there will be a loud "snap" as the tube discharges to ground. Again, I must stress this can be very dangerous, and I don't recommend you do it, but if your going to work inside the set regarless.... then this procedure should make it safer for you.
Posted on Feb 11, 2008
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Colors are not aligned
Can't use the flash focus button or the convergence control crosses +s don't alignes red,blue,green colors.The tv have convergence problems,it dead.Must replaced 2 STK convergence ICS,and some or all it resistors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Alignment problem
Convergence are dead.The tv convergence board must be replaced 2 STK convergence ICS and some or all it resistors.U know how to solders?Have tools,soldering iron,solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300-$350 for parts and labors.
May 30, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic rear projection-red convergence-moves horizontal only!?
The convergence ICs have failed. You will need to install a convergence repair kit. You can get the convergence repair kit for your model Panasonic from www.tvrepairworld.com which contains both of the Convergence ICs , the associated resistors and the cD with detailed repair instructions.
Dec 26, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Aug 14, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Pow lite flashes three times it tries to turn on then shuts down
LED 3 times blinks shows problem with convergence out section in TV and may requires convergence out ICs replacement.
If you are familiar with TV repair and can solder parts on PCB then let me know to provide you more technical info.
Thanks.
Jul 23, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Pt-47wx53g has red ghost. I tried adjusting convergence but some will not adjust
You have a problem with the convergence output IC's. They need to be replaced. This is a very common problem with all projection tv's as those IC's are high current components.
Jun 10, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic convergence- Blue Cross line not able to adjust
The panasonic rear projection convergence repair kit #2 is available for your model at the following link under convergence repair kits which has the ICs and resistors plus detailed instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence problem
Hi, you`ve lost the convergence IC`, requires a good knowledge of soldering and. posssibly an alignment after replacement, good luck, video-tek
Feb 14, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53g will not turn on
Sorry to disagree with the previous hinter, 3 FLASHES is a convergence problem for your model set. This data is direct from the Panasonic manual.
5 flashes is a DG board problem. Unlikely the manual is wrong on their website... (Never hurts to change the convergence ICs anyway) However, the board can only be rebuilt by Panasonic at the Elgin, Illinois plant. You might be able to find a board at a distributor, but anyway you look at it the thing's pretty expensive.
Look on the "A" board for corrosion damage or on the separate plug-in DG board. I've seen moisture condense off the CRT chassis ( or a possible CRT leak) and drip directly on the DG board flatpacks.
Mark
Nov 29, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
