Question about Estate TAWS800JQ Top Load Washer
Washer will not complete rinse cycle and will stop.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Are these your washer symptoms:?
    Fills, agitates, then stops?
    Please elaborate a little more so I can understand what the problem may be. I think I know what it is, but want to be sure.
  • 5,911 Answers
It is NOT recommended to hit a lid on a washer to get it to work. If you have to push on the lid real hard, sit heavy objects on it to get it to work, or open and slam the lid, the lid switch is either loose, needs replaced, or the plunger that activates the switch is broken. Any of the previous mentioned "solutions" will only cause further damage to your washer and will eventually bend the lid to where is doesn't make contact. Fix it right the first time.
Posted on Feb 11, 2008
  • 77 Answers
It is probably the piece that your lid pushes down to let the washer know that it is closed try hitting the lid realy hard.It happened to me i have to do it every time
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series washer
The switch you're talking about is called a "lid switch". It can be by-passed, but it is there for a reason. The switch is used to prevent the tub from spinning or agitating with the lid open. This is a safety measure to prevent personal injury. You mentioned that the switch was "missing". It may have simply come loose and fallen inside the washer between the case and tub. More than likely, it is hanging by a ground wire and a plug. If you can retrieve the switch and screw it back in place on the rim of the wash tub opening, you may actually fix your problem. However, if the switch is broken, you need to replace it. Here's how:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
PS To answer your initial question about by-passing the switch, when you remove the console and disconnect the lid switch, you can take the connector that is MOUNTED ON THE WASHER TOP and remove it by pressing the release tabs and pulling it from under the tub rim. This is the connector plug that runs to the lid switch. Cut the plug from the switch, leaving a couple of inches of wire. Short the two black wires together, insulate the ends and cut the green wire flush. You now have made a by-pass plug. Simply plug it in to the connector that is RUNNING FROM THE TIMER and (voila!), you have a working washer. Keep in mind that now your washer will NOT stop when you open the lid. Use caution if you're going to operate your machine in this manner.
Now...if you're going to go this far, you should replace the switch. A new switch runs about $35 or less. Its an easy repair if you follow the directions. Keep the plug handy in the event that you run into this problem again and need to drain and spin the water out.
Good luck to you and let me know if you need any further assistance.
Posted on Feb 22, 2008
Scott Ellin
  • 558 Answers
SOURCE: Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Posted on Sep 26, 2008
vanni7
  • 163 Answers
SOURCE: HE2 Plus washer will not complete the rinse cycle.
Hi!!! You best been usin he detergent if not you are in trouble..You have a sud built up..clean all the water out and go to sears and buy whirlout for he machine..tell them that you have suds and want to clean it with whirout..good luck..
Posted on Jan 04, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Maytag topload washer is
That may just be a worn out belt. It's pretty easy to replace. Tip back the washerthemobilian_1410.jpg
With belt off turn the pump. It should be pretty easy to turn by hand. Finally if the belt is good and pump is fine then you might have a bad main drive pulley or a badly worn one. The pulley releases the tub for spin. If the pulley is worn out it won't release well and the clothes will be soggy.
I have more HERE
Posted on Feb 10, 2011
Testimonial: "Very useful and great advise"
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Tip
We have a Kenmore 90 series hvy duty top loader, it works fine in wash cycle but...
This advice is for all Whirlpool manufactured TOP LOADING washing machines. This includes Kenmore, Estate and Roper models as well. This is an easy repair that anyone with a little know-how and determination can perform.
1. Under the console you will find the white plastic lid switch connector plug. Unplug the switch from the connector.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located adjacent to one of the lid hinges in the rear.
2. Insert the brass-colored clips into the slot on the washer rear panel first (this is the end of the clip with the 90 degree bend), and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
I hope this information is helpful..
on Jul 26, 2010 | Washing Machines
Will not complete a wash cycle or rinse cycle, stops short
I think it maybe your lid switch. If the lid switch is out it will not spin and sometimes spin or drain. can you give me a model number so that I can further assist you?
May 12, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Estate TAWS800JQ Top Load Washer Logo
94 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
