Question about T-Mobile Sidekick® 3 Cellular Phone
Broken Lcd screen
The back light comes on but thats it. Everything else work but that.
  • E-MONEY Mar 13, 2008
    MY BLACK LIGHT DOES NOT COME ON BUT THE PHONE WORKS.. HOW DO I FIX THE BLACK LIGHT??
My sidekicl lx the screen is craked but everything works except the lcd doesent work.
Posted on Feb 23, 2008
    President:
  • 625 Answers
SupaMan is right about that, your flex cable may not be inserted tightly into the lcd screen itself.
Here is a procedure for checking that. It is complicated but worth a shot before you spedn 50 dollars on a new flip lcd assy.
Check Flex cable connection to LCD screen
Posted on Feb 14, 2008
  • 31 Answers
Well its obvious you might need a screen. but before you buy that, if you've opened yur sidekick before or know how to, then try taking out the screen and taking it apart. The flex cable may not be put or or jus a bit tight or scrambled a bit....
Posted on Feb 12, 2008
The LCD display screen is blank, back-light remains on. Powering off machine to power back on results in loud, abrasive rattle which seems to come from scanner. Unable to do anything with device.
When this happens the first thing you should do is check the connections to the LCD screen. However if it was working fine before this is most likely not necessary since they have to be connected properly to show anything. After that you would need to replace the LCD or the Logic board. If everything else is working properly then the problem is more than likely the LCD needs to be replaced.
Mar 12, 2014 | Brother MFC 6490CW InkJet Printer
Tip
Monitor LCD Screen Replacement With A Laptop Screen
This tip is for the typical PC tech with a shop full of dead laptops and monitors, looking to make an extra Monitor for bench testing malfunctioning PC's. Maybe you're a tinkerer and just have some spare parts laying around, and want to make something cool and easy. Either way, this tip is a fun way to make old dead parts work for you, rather than sitting in a corner gathering dust.
Replacing a Laptop screen is pretty easy if you take it slow.
LCD Monitor screens are actually easy to replace too, if you are careful not to crack anything getting one out and in again.
This tip doesn't address any of the typical replacement methods.
What this does is show you how to use a laptop screen in a standard Desktop LCD monitor.
Having already disassembled your Desktop monitor, and determining that one or both of your backlights is dead, you will most likely begin searching for sources of a new one. Before you do that, try testing both backlights in the dead monitor screen first by hooking them, one at a time to an inverter in a working laptop to verify that both are dead.
Most of the time, you will discover that only one light is dead, and this is where the fun begins.
At this point, you have a few choices to make.
1. Extract a working backlight from a cracked LCD, we all have a few of those lying around somewhere in just about any PC tech area.
2. With the extracted backlight in hand and the old LCD screen still attached to the monitors electronics, remove either of the sets of wires going to one of your backlights, leaving one still attached.
3. Now you can attach the light you extracted to the empty socket your original screens light attached to, while leaving the other one still attached.
4, Now, turn on the monitor and wait for the extracted backlight to come on, if it doesn't switch it with the other light socket plugged to your screen, and plug the opposite light wire back in.
This will do 2 things for you. First, it will be a quick test of your inverter, and second it will verify that you do or don't have at least one working backlight still functioning in your monitor.
Remember that with most LCD monitors, just one backlight can provide enough illumination for your screen to show a very crisp picture.
The problem appears though, when we decide that our existing LCD is dead because we dont see it light up.
The solution for this is to simply disconnect the dead light wire from the existing inverter plug leading to the LCD screen, then replacing that with a working light from the cracked screen without disassembling the LCD screen itself. If you did everything right, your old dead screen will be working as it should. Be sure you swap the backlight connecting wires so that your Bright/Dim controls work as they did before.
You see, most dual light inverters work the same as a standard twin tube household flourescent light. When one goes out, they both eventually stop working. So, adding that second light completes the circuit, then swapping light socket connectors turns your backup light tube into the primary light, instead of the secondary.
Now, if THAT trick didn't work, you can move on to the Laptop LCD trick, which is pretty much what you did before, except that the Laptop LCD usually only has 1 light tube. So for this to work, you can complete the lighting circuit by simply adding your spare backlight tube to the second open backlight connector, then installing the LCD to your monitor.
Many of these Laptop LCD screens are the same height and width as comparable Desktop screens, but they are also thinner, and will have to be glued or taped to the frame from the inside. Everything else connects exactly as the original screen, but may need to have wire added to the Laptop backlight wire so it reaches the power source.
I figured this tip was worth posting, since I just did this trick with a 15" polaroid HDTV/HDMI/HiDef Television/Monitor combo.
The model I have died a few months after it was bought new from Walmart, and the customer just didn't feel like paying $129 for a new screen.
Being the packrat I am, I just couldn't bear throwing it away, figuring that some day I would find a matching screen. As you can see, I got tired of waiting. The pictures of my project are below.
That bright line of light isn't the flash from my Camera, it's the flourescent light tube from a broken LCD screen placed on top of the steel housing.
The incidental effect of that light is that my back wall is a nice nitelite, and hooking up new components is a lot easier. Yes I could have blacked it out, but I think I like the added light behind the TV.
I hope this Tip comes in handy for you.
Bob S.
on Apr 08, 2010 | Computers & Internet
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Aug 01, 2011 | Dell Inspiron 6000 Notebook
My screen is extremely dark. In the right light, you can make out things, but it is otherwise impossible to see. I tried pressing the "Fn" button and the "F7" button that controls the brightness by the key...
Hi Sarah, the problem is in the lcd inverter which lives behind the screen bezel and beneath the lcd panel. The inverter is a small electronic board that connects the lcd panel to the motherboard and is responsible for powering the light bulb that lights the panel itself. These bulbs are built into the panel. The inverter is inexpensive to replace and only takes a short time to change out. In most cases you only have to remove the plastic belzel that surrounds the panel. Unless the laptop was banged around and the bulb has been broken or a wire harness has come loose from the inverter's socket, I would go with an inverter failure. You will know when the bezel is pulled, because a new inverter can be test fitted and run to make sure the screen lights before putting everything back together. If it is just a loose plug, then that can be accomplished at that time too without too much work. In most cases, remove the rubber bumpers because they usually hide the screws, remove all screws holding the bezel, then from the inside edge of the bezel pull the bezel up and toward the out side to release it from the lid assembly and then just work your way around the whole perimeter until the bezel comes loose.. Once the bezel is off you will see how everything is mounted and how the wire harness is plugged in.
Jun 25, 2010 | Everex StepNote NC1500 Notebook
How to troubleshoot a video camera when the LCD screen is dark or has no display, in a Sony handycam DCR TRV22E mini
If you see correct picture in Eye Piece view finder but dark picture in LCD that shows problem with connecting flexible wire between LCD board and Camcorder main board. It got cracked/ damaged or broken after some time due to open/ close of LCD in its position.
Replace that flexible wire and problem will be solved.
Post back further question if you have any.
Thanks.
Dec 08, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Computer screen goes blank after a couple of seconds
the back light of my hp w1907 will only come on for a second than go back off?? the rest of the monitor is working can see the image if you shine a light on the screen ..any help??
Comments: Oct 26, 2009 - so this monitor was not in warranty so i took it apart i found a wire broken off one of the backlight bulbs, ( be very carefull the bulbs all four of them and the lcd screen are very very fragile ) so i soldered the wire back on and put it back together and rechecked it it has been working like new
Nov 24, 2009 | HP w1907 LCD Monitor
Broken screen
If you mean by "broken" it does not light up, likely your inverter is shot.
All LCD screens depend on an inverter to light them up, and they are relatively easy to install. You do not have to replace the screen, unless it is physically busted. Same thing happens on largescreen TVs. How to tell? haven't a clue. I have heard that if you unplug your CPU for sufficient time, your password will disappear. I'm afraid that you may need to do a complete system install to start afresh if no one else hs any ideas--and check with HP--they are pretty helpful
Mar 12, 2008 | IBM ThinkPad T23 2647 Notebook
Nokia 6133 LCD Replacement Trouble
my guess is that you messed with something while you were prying it open.
I have the nokia 6126 (very similar) with a broken screen but i get it open, could you help me with that
Feb 14, 2008 | Nokia 6133 Cellular Phone
LCD screen nonresponsive
if your . . . remote . . . works ok ? your touchscreen internal connector could be loose disconnected - or defective ( not field repairable ) ;
Oct 20, 2006 | Sony Handycam DCR-HC30 Mini DV Digital...
T-Mobile Sidekick® 3 Cellular Phone Logo
156 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
