Washing machine stops in rinse cycle.
My washing machine will wash my clothes but when it gets to the rinse cycle it stops running. When I open the door I can see water in the tub and the clothes are soaking wet. I have tried numerous times to restart the washer but it keeps stopping in the rinse cycle. Is it a relay problem? Any one experience this before?
  • 7 more comments
  • rotag Mar 07, 2008
    I have the same problem. The washer stops in mid-cycle. I see all the suds and error code d5, i believe. I can't get the thing to go. If I turn it off and then back on it sits and grinds for a few minutes, doing nothing other than making a grinding sound. Then it starts the entire wash over from the beginning. I purchased this Maytag Neptune 27" front Load Washer #MAH6700A in September. Should I be calling for warranty service before the thing stops working and I am out of warranty? Please help!
  • Anonymous Jun 16, 2008
    I have a Maytag Neptune will not completed cycle spin
  • errin99 Jan 17, 2009
    I have the same problem almost, mine stops right before it fills, I just turn it a click over and it will fill and rinse .... but i dont wanna do that forever.. wondering if mabie there is a solution? One that is easy i dont have alot of money for a repair man?
  • Anonymous Mar 12, 2014
    machine stops between wash and rinse cycle
  • Anonymous Mar 13, 2014
    The machine stops, unlocks, but clothes are still soaking wet. Appears to be stopping prior to rinse and spin cycle.This is a front load affinity.
  • Anonymous Mar 15, 2014
    I put washing on and sftr it has completed bith the spin and rinse lights are flashing. Open the door and the clothes are very wet as if thry haven't had a rinse/spin
  • Anonymous Mar 19, 2014
    can it be unbalance?
  • Anonymous Mar 21, 2014
    trying to wash cloths but sd keeps popping up how do I get rid of the suds problem in washing machine
  • Anonymous Mar 22, 2014
    the r
    the rin
    the rinse cycle water levelin my moffat top loading washing machine is very low and does noy cover the clothes and dosent rinse them properly
  • 5,911 Answers
Okay...I asked you a question in your other posting before I saw this one. This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plunger on the lid itself. Make sure the plunger is not broken off. This will also keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and agitate, but will not start the rinse or drain cycles. If you wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Feb 11, 2008
The machine may not be draining and spinning due to a foreign object in your pump. For front loaders (I have the AWM6100) the filter for the pump is on the bottom right of the front panel of the machine.
Turn the machine off.
Take the round cover off the filter by levering the top section of the cover.
Turn the filter so that you can remove it. There may be something stuck in there. Ensure it is clean and free of debris.
You will see the propeller type part that sits behind the filter, give it a little turn to ensure it is turning freely.
Replace the filter securely and the cover.
That may be what you needed!
Posted on Jul 05, 2008
JEff, In regards to the Washing machine stops in rinse cycle Posting. What is the switch called. I have a Kenmore washer
Posted on May 07, 2012
Frigidaire Model # GLTF1670ASO rinse cycle is not working
ARE YOU WASHING IN COLD IF NOT YOUR WATER VALVE MAY BE BAD ONLY GIVING HOT CLOTHES WONT RINSE IN HOT
Jun 16, 2014 | Frigidaire ATF6000ES Front Load Washer
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Nov 01, 2013 | Zanussi Washing Machines
My Kenmore washer will wash the clothes but it will stop at the rinse cycle. Thank you. Ms. Zelly
he lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 23, 2011 | Washing Machines
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Spin mode does not work
    Dear "FixYa,"
    I have fixed the problem with my washer.
    I started clothes washing machine with one load of clothes.
    Wash and rinse process completed, as it came to spin,
    Machine stop, only I heard was running motor. I opened
    machine and found coupler is cracked (broken) and was
    unable to rotate the gear.
    I replaced new coupler and machine started to work normal.
    Thank you
    Kanu
    Apr 18, 2009 | Whirlpool Washing Machines
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Washing Machines Logo
    17,648 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
