Konica 1015 "Add Paper" prompt appears when feeding from any tray including the bypass or manual feed. It may be an indicator of a failing main motor - can't find one to purchase or even get a quote. Thanks. Tom
  • 1 more comment
  • Tom Schneider Feb 11, 2008
    No, I have not. What is the procedure?
    Thanks.
    Looking ahead, if the drum cleaning blade is "flipped" and toner recycling coil is clogged, what is the correction procedure. Answering this ahead of time will save me a trip to my customer's office.
    Thanks very much.
    Tom
  • brian c
    brian c May 11, 2010
    That's a possibility.
    Have you tested the main motor?
  • 589 Answers
Power on the machine while holding the 4 & 7 keys
hit the P then 40 then P again
Hit the print key
You should hear the main motor turning.
To exit the service mode, turn machine off.
FYI - this model (as well as the 1120) was notorious for the drum cleaning blades "flipping", and the toner recycling coil getting clogged, therefore binding up the drive mechanisms.
I personally have never had to replace a main motor on these.
If you need more help, please don't hesitate to ask.
Posted on Feb 11, 2008
  • brian c
    brian c Feb 11, 2008
    Actually, depending on the firmware version, you may not have to hit the "P" key.
    Just turn it on while holding the 4&7, enter "40" on the keypad, and hit print. Then press stop / clear to stop the motor.
    IF you can't hear the motor running, we can troubleshoot this further.
  • brian c
    All you will really need is the toner vacuum to give it a through cleaning.
    You will need to pull the drum carriage out (obviously).
    If the blade isn't damaged, you may be able to reuse it.
    I would bring a blade just in case - and a drum if you have one.
    Be sure to apply setting powder (or whatever method you use when replacing a drum / blade). Personally, I use a little bit of CRC silicone spray lubricant on a cloth, and buff the drum with it. I've heard of tech's using WD-40 - but in VERY small amounts. It will take 40-50 copies for the drum to "recover" from the buffing, but you can be sure the blade wont hang up on it.
    To narrow down the problem even more, use that test procedure with the drum carriage removed. Close the clam-shell as if the unit was in, and close the front door.
    If the motor turns without the drum carriage installed, then that's what is binding.
    NOTE: Do NOT try to run the machine in any other mode besides the 47 service mode mentioned! But i'm sure you already know that.
On Konica 1212 what does J11 mean and F54?
J11 means Jammed on 1st paper feed tray & F54 means your key swith is Open(disconnected).
Dec 05, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
Konica minolta c350 error code c204
C 204 Tray 2 feeder up/down abnormality.Check the M9 paper feed tray 2 lift up motor connector for proper connection,the PS15 paper feed tray 2 upper limit sensor actuator,the motor coupling.
Jul 27, 2014 | Konica Minolta bizhub Office Equipment &...
Di2010
C0960
Manual Bypass Paper-Lifting Failure
The Manual Feed Tray Lift-Up Sensor (PC29) is
not blocked or unblocked even after the set period
of time has elapsed after the Manual Paper Feed
Pick-Up Solenoid (SL3) is energized after the manual
feed paper take-up operation has begun.
Check the bypass tray for obstructions and damage.
Jan 23, 2013 | Konica Minolta Office Equipment & Supplies
How do i print 6 3/4 return size envelopes on a sharp 2600n
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Oct 20, 2011 | Sharp MX-2300N Color Copier
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
Malfunction Detected C-0206 on Konica Minolta C351
this error code means that tray 3 paper could not lift up to the feed rollers. open the tray and check the paper tray and checkthat the paper is loaded correctly pull all the paper out of the tray and check to see if any is folded or crumpled if the paper is ok it could be the lift motor has failed or the main boardPF or main boardMC or the dc power supply needs to be replaced.
to reset the code leave the machine on and open then close the front door
Nov 11, 2009 | Konica Minolta bizhub C351 All-In-One...
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
292 people viewed this question
jasbo
jasbo
