Question about Freezers
Rust On Bottom Of Chest Freezer
I bought a second hand small chest freezer and the bottom is rusting.
How can I prevent this or do I need to replace the metal pan liner it sits on?
Could the rust eventually eat to the inside of the freezer?
    President:
  • 1,314 Answers
Id sand it paint it with white rustolm and go from there and no it couldn't there is a layer of foam between the bottom of the outside and in side
Posted on Feb 11, 2008
Rusting liner of a chest freezer.
Hello nnwaldron - Try the following suggestions below; if it prove to be ineffective then the liner will need replacing.
1) Dip a moist, soft toothbrush in a box of baking soda. Very gently, in the direction of the stainless grain, rub back and forth on the appliance. The mild abrasive action will get into the grain without damaging it. You can use your finger (instead of a toothbrush) for even better results.
2) Rinse the baking soda off with a warm, damp (not wet) paper towel. Dry thoroughly. You may see or smell rust on the paper towel or toothbrush. That means it is working!
3) Finally, dry the appliance thoroughly. You don't want to leave any water that could cause more rust.
Feb 17, 2013 | Frigidaire 13 cu. ft. / 368 liter Chest...
The outside front of the freezer case gets hot.
It's normal to touch it hot on the outside front.
Because it has heater to keep moisture out in the body metal of the freezer.
Those moisture if not heated to dry, can cause rust build up.
Rust build up can destroy the metal body of the freezer.
Thanks for asking.
Jun 29, 2011 | Woods Chest Freezer C1501W3
There is a small hole in my g.e. chest freezer.
that is the drainage hole where water can pass out from .
Feb 18, 2010 | GE 7 cu. ft. Chest Freezer FCM7DR
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
We were given a fairly new chest freezer (a smaller-med size) however it has some rust damage on the corners and expecially on the bottom. Can I paint over this? What should I use? Thanks!
Go to the hardware store and get some rust removing jelly. Sand the area with emery cloth and then prime the area and paint it with an appliance spray paint that matches your color
Apr 16, 2009 | Freezers
Freezer not freezing!
try plugging the electric cord into a receptical
Feb 18, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Dec 26, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kelvinator Chest Freezer will not cool after spray painting rust spot.
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Oct 10, 2008 | Freezers
Freezers Logo
587 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
