Question about Dryers
Bosch condenser tumble drier.
Water is building up in the reservoir at the bottom of the machine but is no longer being pumped up to the removable water canister at the top
  • 55 Answers
Maybe the pump is bad. With the power off, remove the power wires from the pump terminals. Then connect the power wires to an electrical tester light or meter. Then turn on power and run the machine in a dry cycle. If you get power, then you know that power is getting to the pump abd the pump is bad.
Posted on Feb 12, 2008
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
I have a two year old Bosch Ecologixx 7 Tumble Dryer (WTW84560GB/02) whose condensation compartment full indicator is being activated increasingly early, to the point where I am needing to empty the...
I had exactly the same problem and got it fixed by the Bosch repair service today.
The culprit is that in certain areas there may be algae in the air that thrive to grow in the main water reservoir and clog up the water pump that fills the condensation compartment.
(note: There are two water tanks in the Ecologixx 7 - one user serviceable condenser tank up top and the non-user serviceable main water reservoir sealed inside the machine)
This is main water reservoir is located sealed under the water pump under the tumble dryer drum.
Dismantling instructions: 1. remove the top of the tumble dryer first (two screws at the back 2. remove the right side panel with another few screws (looking from the front) 3. disengage the multi-tooth elastic band by twisting the spring loaded roller at the bottom).
After this you have access to the water pump and the Styrofoam float that triggers the empty condenser tank warning.
If the pump is entirely clogged you might need to replace it and the float.
Then clean the bottom water reservoir from the algae infested water with a pump+hose and a bottle washing brush and circulate clean water through the machine (re-engage the elastic band before running the engine) with the Warm-program.
To kill the algae you need to run about 250ml of clear raw vinegar through the pump system by running the machine in the Warm program for 10min and then rinse the excess vinegar out by putting about half a condenser tank of warm water into the machine and running the Warm-programme for 30min. (this will release the clean water into the condenser unit for the self-cleaning function and then pump it back up into the condenser water tank and dilute and circulate the raw vinegar out of the machine).
You should also do a vinegar sanitization run before all extended periods of disuse of the machine by pouring 250ml of vinegar into the large round hole under the top condenser tank (this is where the condensed water is poured for the self-cleaning run).
Run the Warm-program without the condenser tank in place until you can verify visually that the pump is circulating the vinegar through the hose in the top left back corner of the condenser tank opening (there is a overflow drain at the back so everything coming up goes promptly back down into the main reservoir (small hole in the back corner bottom).
Then place the condenser water tank half full with hot water (not boiling) and let the Warm-programme run for 30min to dilute and circulate the vinegar-water solution out of the machine back into the condenser reservoir.
Feb 05, 2011 | Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Water tank full (!) in bosch tumble dryer WTE86301gr
As a matter of fact I have solved the problem. The dryer is now fully functioning again. :-)
I'll try to explain how to fix the problem:
The water that condenses in the condensor (doh!) drips down into a container situated below the condensor. The moist air that passes through the condensor is the same air that circulates via the clothes, thus it also contains some lint that the filter doesn't catch. Over time there will be some build-up of lint and mucus (?), clogging the tank AND a sensor that sends a signal to the electronics to start the pump that evacuates the condensed water to the removable tank in the upper part of the machine. This messes up the function of the water evacuation system.
Alright, pull out the condensor and find a hatch in the 'floor' in the farther part of the compartment. Below the hatch you'll find the container that collects the condensed water. Start by cleaning it as thoroughly as you can. There are a few 'nooks and crannies', take your time, also flush with some fresh water and maybe some gentle cleanser to get rid of the mucus. The pump and the sensor for the pump are located in the left part (viewing from front of the machine) of the container. Try to flush there as well.
If this procedure doesn't solve the problem you'll have to disassemble the machine to also be able to remove the pump and sensor housing. I had to do this on mine. Quite a few screws to remove and keep track of, but pretty straight forward if aren't too uncomfortable with 'fixing things'.
I have some pictures of the 'project' somewhere, let me know if you would like to see them or if I may help you some other way.
BR /Hans
Mar 10, 2010 | Bosch Dryers
HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Jul 09, 2008 | Dryers
Bosch tumble dryer
I've sorted mine this morning. First, disconnect from the mains - VERY important! Pull out the metal condenser unit at the bottom, and behind it, there's a small hatch in the bottom to the reservoir. This can get gunked up with water, and is very difficult to clean - HOWEVER - I've found a really easy way of cleaning it. I've got a VAX carpet washer with a hose attachment, and I simply sucked all the water out using that. If you don't own a carpet cleaner maybe borrow one. I did this this morning, and my tumble-dryer's still running happily after an hour! It is possible to clean it out without vacuum, but it takes a LOT longer, and the vacuum of the cleaner pulls out gunk that is hard to access. Another place where gunk collects is behind that hatch right at the back - there's a tube up to the right. I pulled out quite a long chunk of lint. However, that wasn't the solution on it's own, I still had to clean out the reservoir as above.
Jul 03, 2008 | Bosch Axxis WTA 3510 Electric Dryer
My is70c tumble dryer is leaking water from the main filter at the bottom?
This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced.
Apr 29, 2008 | Whirlpool LER4634J Electric Dryer
My tumble drier no longer condenses! Water comes out the middle of the machine.
Hi LesleyB, I have just read your question on Fixya .com and I have the same problem with my dryer. I know your question was raised some time ago with no answer on Fixya...but I was wondering if you ever got to the bottom of the problem? Like I say I have the same model here in the UK and cannot find anyone who knows what the problem is (without charging me the earth to come look!) Hope you can help...Thanks Simon B, Manchester...UK
Sep 29, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
111 people viewed this question
Top Dryers Experts
Marvin
Marvin
