Question about Toshiba 52HM95 52" HDTV Projection Television
Bright spot on my 52hm95
About 1 yr after purchace (no warranty) it developed a bright spot in the bottom center of the screen...this bright spot keeps growing upward. now it looks like someone is holding a flashlite from the bottom up on the screen. cant find a repair man in jersey...thinking of opening it up and attempt to fix myself...worst that could happen is i'll end up just throwing the damned thing out!
    President:
  • 4,402 Answers
can see it in certain lighting and even when the TV is off! It will appear lighter than the surrounding areas at times and can be annoying. I called Toshiba and had a service man come out and even though he acknowledged that this is common, Toshiba will not replace the screen.
Posted on Feb 11, 2008
Why does my led screen have a white spot
may be the panel, in which case it should be under warranty. This unit has a 1 yr mfr warranty , if less than 1 yr old it would be covered. contact servicer for service immediately before warranty expires
Sep 09, 2014 | TCL 48FS4610 48 LED HDTV 1080p 120Hz Slim
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
My ipod touch has a crack in the middle of the screen, from top to bottom. What do i do to get another one from you guys, because I have 2 yr warranty plan for it.
If you have a 2 year warranty plan for it, then you should be able to get it replaced on the spot I believe. After all, I believe that is part of the 2 year warranty.
Feb 07, 2011 | Apple iPod touch
My SAMSUNG DLP HLT5675SX TV seems to develop little black spots all over the screen and after a while these black spots become bright white spots. In fact if a non-used Input is selected and the screen is...
It is the chip that controls the millions of mirrors inside the tv. If they are black, they are stuck closed. If they are white, they are stuck open. I JUST had the same the same thing happen with mine. I bought it 3yr and 2 months ago and I had an extended warranty on it for 3 years. Well, needless to say, it was out of warranty and I was pissed. The store I bought it from suggested I call Samsung. Which, I did. They asked for the model number and told me that my model (hlt5675sx) was one of the ones that is covered becasue they had a problem with the chip. Within 2 weeks, my tv was fixed by a repairman who came to my house. It works perfectly, now and it didn't cost me a penny. Good luck.
Jan 11, 2011 | Samsung DLP HL-P5663W 56" TV
Yellow-green spot in center of screen
Defective light engine. Contact Sony support. They warrantied a lot of these sets even after the warranty had expired because of so many going bad after 3-4 yrs. Have the complete model and serial number ready when you call them.
May 20, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Spot on LCD screen
I would call the company anyway and complain! A lot of times they will fix the product Free of charge if you have ran over your warranty (screen will need replaced!)
Dec 19, 2008 | Cameras
Yellow spot in center of screen
I have recently developed the same yellow spot problem on my Sony KDF-E50A10  50" LCD television...a large yellow circular hue that takes up the bottom center of the picture and is especially noticeable against a white background.  It has been diagnosed as the optical block (light engine) and without an extended warranty Sony refuses to assist with the repair cost.  Repair was estimated at $1,100 plus tax and travel fees to my home.  So you see, it is not only a Hitachi problem.  You would think they could build something that would last more than two years considering the initial cost of over two grand for the TV !
Jan 03, 2008 | Hitachi 50V710 50" Rear Projection...
Screen problem
your unit needs the optical engine cleaned(the lcd panels).This should cost about 300 at a local tv shop
Mar 22, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Toshiba 52HM95 52" HDTV Projection Television Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
