Question about Protron PD-DVR100 DVD Recorder
Clock format The clock gives the time in 24 hour mode. The LCD readout has an "AM" and "PM", but no instructions on how to change the mode from 24 hour to 12 hour AM and PM. What do I have to do to change to 12 hour mode? Thanks.
  • Jeffery English Feb 18, 2008
    I have the same problem. The clock shows the time in 24 mode and I would like it to be in 12 hour mode. No instructions are given in the owners manual or any other manual received when purchased. Hope to find a resolution.
24 hour mode is all there is. Time to learn military time.
Posted on Feb 23, 2008
SOURCE:
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
Apr 06, 2016 | Brookstone Audio Players & Recorders
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How to change my TAKSUN TS-623A clock from a 24 hours display to AM/PM?
Press buttons in this sequence ->
M -> M -> M
shows sec blinking
-> D to reset seconds
-> S to move to min - hr - date - month - day - sec ....
-> M to finish :)
Hold S and D to change to 12 hour in clock mode.
Mar 17, 2014 | Health & Beauty
I have a blue hat toy co. time and space projection alarm clock. it says it is a 12/24 hr clock but we can only show military time. is there anyway to just show the 12 hr clock. it is confusing to my son....
We also purchased the same alarm clock and I accidentally figured out how to convert to 12 hour (AM/PM) format from 24 hour format. Once the time is set correctly, and you are out of the time set mode, you can press the UP key and it will toggle between the formats.
Dec 26, 2010 | Sharper Image Blue Hat Toy Company Kids...
Activate the 24 hr clock function
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
Mar 10, 2010 | Watches
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
Sep 09, 2008 | Sharper Image SI686 Clock Radio
Protron PD-DVR100 DVD Recorder Logo
406 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
