Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark Printer Install - No Communication Error
So I got this new printer, a nice Lexmark X5495 all-in-one, fax, scan, copy, photos, prints, all the bells & whistles, right? I install it step by step just like it tells me to do. Everything shows fine, all appears hunky dory. Go to control panel, it says ready, big happy checkmark, it's set as default printer, it's online. Just one problem, it won't print. I get this nasty message that says there's no communication between the computer and printer. I tried 3 different USB cables. I unplugged, restarted, rebooted, tried every USB port on my puter, no go. Same thing. I checked windows firewall, the Lexmark stuff is all checked as exceptions, meaning they are being allowed through. I deleted the other 2 printers from the system. I uninstalled the new printer and reinstalled it - 5 times. I just have the feeling it's something in where the USB cable is hooked up. I have 4 USB ports in the back of the puter. I have 3 in front. All the troubleshooters tell me to check the USB connections and cables, then restart. No go. Same thing. I have Windows XP Home. I have listed this problem under Lexmark X5470 cause the 5495 wasn't listed.
I've been at it for 5 hours now. I know it's something simple and stupid, but that's me - simple and stupid. Any ideas?
INSTALL LEXMARK X5740
  • 2 more comments
  • Anonymous Feb 16, 2008
    computer not communicating with the printer. changed usb restarted computer,re insatlled disk
  • Anonymous Feb 18, 2008
    same problem as showing on screen
  • soina Feb 20, 2008
    same problem help going insane.
  • Anonymous Jan 19, 2009
    Same problem, we tried the printer on 2 other PC's and both worked fine. Tried other printers on the problem PC and they worked fine. No idea where to look now.
I had the same problem with a X5470 and fought it for a couple of hours. I installed and reinstalled the software, tried different USB cables and ports, etc. It would print OK from the front panel, but no communication with computer. On a whim, I disabled Norton Virus protection and it started working. When Norton was re-enabled, it wouldn't print again. Obviously some conflict with the two, but I still haven't figured out a better workaround yet.
Posted on Feb 24, 2008
    Genius:
  • 3,587 Answers
One more thing you can try..did you do a menu test page, from the front panel, to see if the printer has any basic functionality? Also, the disk that comes with those printers MAY NOT be the most up to date. You may want to download one that's more current. Got backup?
Posted on Feb 11, 2008
    Problem Solver:
  • 10 Answers
Best advice is to plug it into another computer. if it still does not connect then obviously you have a out of box failure. Send it back to supplier. If it does print, then take your pc in for a checkup. If you plug any other devices into the usb port, does windows pick it up? If not there is your problem.
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
866
Posted on Mar 02, 2009
4 Suggested Answers
SOURCE: Lexmark Printer Install - No Communication Error
Hi, Maybe you can reload windows XP drivers. from this site: Photo Paper (Letter - 20) -- Lexmark United States Good Luck
Posted on Jan 15, 2008
  • 237 Answers
is the printer in its own USB port? Some printers that "talk back" to the PC do not like to share a port so do not have it on a USB HUB.
Posted on Jun 25, 2008
rjwharris
  • 102 Answers
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 03, 2009
Wont scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Keeps telling me to enable bidirectional communication
Hi:
When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
Andrew.
Feb 27, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X5495 printer cannot communicate with the printer, I can scan images from the same printer, but cant print. Tried to unplug the cables, restarted the systems, uninstalled and re-installed the...
If you can scan the USB port, it should be OK. If "copy" works correctly and you have recently installed drivers, try resetting your computer and selecting the printer as "default." Check if there is an impediment on the printer panel, blank cartridges or another error. The printer can scan but can not print if it has empty cartridges. Study the user manual on http://publications.lexmark.com/publications/pdfs/2007/5400-plus/v6592051_en.pdf
Nov 04, 2017 | Lexmark X5495 Printer
Can I download the Lexmark X8350 without the cd to my new computer
you can install your printer to your computer by downloading the drivers from the Lexmark website
Dec 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark x5495
Lexmark does not allow refilled cartridge on any of their products.
Lexmark, HP and Canon and-many other vendors use proprietary code to protect themselves against the damage of OEM inks.
All companies will void warranties.
Apr 24, 2009 | Lexmark X5495 All-in-One &USB...
Lost the cd how to install printer to comp again?
plz check the manufacture website for the driver download
Jan 13, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
LexmarkX5495 won't scan....can you help?
go to www.isohunt.com and download driver detective with key. Install driver detective. And let it to search for the drivers your system needs to operate any hardware. When it searches the drivers for your MFP then install it.
cheers
Dec 07, 2008 | Lexmark X5495 Printer
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
Apr 17, 2008 | Lexmark X2500 All-In-One Printer
1st -make sure that the USB cable is connected on the correct port of your printer - you might be plugging it on the ports of the telephone - you got 3 ports there - 2 for the telephone ports and 1 for the USB
2nd- check your service if print spooler and lx devices are started (lexbce or lxdcu) - if not.... start it
>start >run>type services.msc > enter
3rd- if still no go - uninstall your driver and download windows vista x64 printer driver on their website
Jan 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
361 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
