Back to:
Tags:
RCA VR622HF VHS VCR
Problem with S400 and IR with new VCR
By Putty - usenet poster
Just got a S400 and am having trouble connecting to my new VCR. Just
bought a RCA VCR...VR622HF. I selected VCR type in setup (RCA) and
went thru 20 different remote codes, but none worked. Then I tried to
train the S400, the "next" button came up and being trained, but when
I tried the new "learned" code...still no play with the vcr.
Any suggestions?
Thanks,
Steve
to reply, remove "nospam" from address
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
maartenw
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks for the reply, but I still couldn't get it to work, so I bought
a Sony SLV-998HF.   Works great.
Steve
On Tue, 25 Aug 1998 08:25:17 -0700, Mike Iampietro <m @no.address>
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problem with S400 and IR with new VCR:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Odud
Rating: 0%, 0 votes
1) Make sure the correct SmartCable type is selected in Setup/SmartCable
2) The SmartCable transmitter should be 6 to 8 inches form the VCRs IR
receiver. You may have to experiment to find the best position.
3) If you are using an 006 SmartCable, be sure to move the switch on the
SmartCable to the training (rear) position to train, and then back to the
normal (forward) position.
4) There's a little home test you can try to determine if the Smart Cable
is faulty.  Place the infrared sensor in front your camcorder.  Place
your  camcorder in the 'camera' mode. In Studio 400 got to Setup/VCR, and
select any of the pre-created VCR profiles.   Go to Make Tape mode and
click any of Studio 400s VCR transport buttons
When looking at the infrared  transmitter through the camcorder's view
finder, you should see the  infrared sensor blink.  If you see it flash,
then the SmartCable is
working properly, if it does not, then the cable is faulty.
5)  It may be necessary to adjust the SmartCable IR frequency. There is a
small screw located beneath a hole in the SmartCable IR head. First mark
to present position of the screw. then turn it 1/8 of a turn and test
again. Repeat until you find the best position.
Mike Iampietro
Senior Product Manager
Pinnacle Systems Inc.
m @no.address
as a defense against spam I have deleted my reply to address
to reply please replace no.address with pinnaclesys.com
Studio 400 Web Forum: http://webboard.pinnaclesys.co m/~2/
Thank You!
Can you Help with these VCRs problems?
VCRs
I have connect my SD-V394 Toshiba DVD/VCR combo to my Sony...
VCRs
Does anyone have the new codes for the ntl box in ireland?...
RCA VR622HF VHS VCR
RCA AccuSearch Four Head Video System
RCA VR622HF VHS VCR
I bought a used rca vr622 hf vcr plus, there is no remote....
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
