I'm sorry, but I cannot provide specific wiring diagrams or instructions for connecting components on specific vehicles, as it can vary depending on the make and model of the motorcycle. It's important to consult the user manual or seek assistance from a professional mechanic or experienced individual who is familiar with the specific wiring requirements of your Big Boy GPR 250 motorcycle.
In general, the connection between a rectifier and a CDI (Capacitor Discharge Ignition) module typically involves the following steps:
Locate the rectifier and CDI module on your motorcycle. Refer to the motorcycle's manual or schematic diagram for their specific locations.
Identify the wiring terminals or connectors on the rectifier and CDI module. They are usually labeled with letters or symbols.
Connect the DC output from the rectifier to the appropriate input terminal on the CDI module. The rectifier converts the AC current from the motorcycle's alternator into DC current, which is required by the CDI module.
Connect the CDI module to the ignition coil. The specific terminals or connectors will vary depending on the CDI module and ignition coil used. Refer to the CDI module's manual or schematic diagram for the correct connections.
Double-check all the connections to ensure they are secure and properly attached.
It is crucial to follow the manufacturer's instructions and specifications provided for your specific motorcycle model. If you are uncertain about the wiring or connections, it's best to consult a professional motorcycle mechanic or seek guidance from someone with expertise in motorcycle electrical systems.
There is either a shorted part in the power supply section or a shorted part (say a transistor if it uses them) in the main amp section. This will be located on the big heat sink. Power supply culprits are transformer, any semiconductor device, such as power regulator, rectifier etc.
Vary low should never make no start conduition.
Sounds like you have a muility meter to ask for voltages .
Try this disconnect the negitive from the battery .Set the meter on the 20 volt DC scale .Go red lead to posivite and black to engine block or any known solid ground .If you read voltage something is shorting
If the voltage 2 -3 volts it could be switches lights ect .If its 5 volts or over then its something that draws a lot of power like a bad motor .
At any rate if you read voltage pos to gr with gr disconnect from bat their is a short .
You can try pulling fuses 1 at a time to see when it stops .This will tell you what circuit the problem is on and sometimes the starting motor will short interinaly this will kill the bat fast
no!
CDI MODULES (IGNITORS)
What is a CDI module? A typical CDI module consists of a small transformer, a charging circuit, a triggering circuit and a main capacitor. First, the system voltage is raised up to 400-600 Volts by a transformer inside the CDI module. Then, the electric current flows to the charging circuit, charging a capacitor. A rectifier inside the charging circuit prevents the capacitor from discharging before the ignition point. When the triggering circuit receives triggering signal, the triggering circuit stops charging the circuit, allowing the capacitor to discharge rapidly to the low inductance ignition coil, which increases the 400-600 V capacitor discharge to up to 40 kV at the secondary winding. This 40 kV then jumps the spark plug gap. When there is no triggering signal, the charging circuit is reconnected and starts charging the capacitor again.
Your bike is designed to have a 35/35 watt headlight bulb. Regardless of fitting a slightly higher capacity battery and rectifier, you have probably blown the rectifier, battery and possibly the alternator. HID is too powerful for your poor little bikes electrical system to deal with. I would try to get a halogen 45/40 watt bulb and try that if your electrical system is still OK.
Yes almost certainly if it (the rectifier) has gone short circuit, but you should be able to test the rectifier with a test meter; disconnect mains and rectifier, forward and reverse resistance should be low and very high for each diode leg in each direction of test leads (4 diodes if it has 4 wires)
test each leg both ways, or get testmeter with diode test
the bridge rectifier is on the board found in the bottom of the machine on the right hand side when viewed from the rear of the machine
disconnect from mains supply before touching anything inside
Hi our tv set need to be serviced. Here are some tips: 1. Open main fuse. The fuse is clean but interrupted. You can try replacing it with one o the same value. 2. Fuse Blown or blackened. Short in the rectifier bridge or in the switching transistor. Out of the power supply: supply line rectifier (100/150V) shorted.
as your reg. output is 40v & you have checked every possible things responsible for it.
my suggetion is that
first you isolate power supply from hor.section & see if power supply output is ok.
if it is ok then check for short & leakage in h/output like
1 hor.output tr.
2 diode or cap in eht winding.
3 check for print near eht transformer.
4 disconnect yoke connector & check .
5 & finally eht or flyback transformer.
MORE INFO
More info PlZ
