Question about Toshiba 1370 Black and White Copier
"Bulb" doesn't light, no exposure, blank copies
How do I replace or fix a "bulb" that is not exposing the paper to copied?
    Scholar:
  • 53 Answers
Dont know the model, but in most cases-take off the platen glass, usually fairly obvious, the lamp is usually held in by a spring clip pushing on to each end.It is usually helpful to loosen the screws holding these clips to allow you to pull them away.Try to avoid bending the clip as it won't make good contact.Note DO NOT handle the lamp with bare hands..it may cause it to fracture when it gets hot (grease from your handprint) Handling the lamp is easier by folding an A4 sheet of paper into a strip, folding it around the lamp, fixing the lamp in then carefully withdrawing the paper. I suppose it is not necessary to tell you to unplug the machine first-power can be on the lamp even when switched off and it can bite you!
Posted on Feb 13, 2008
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
Copies are too dark. If I lighten them up manually they are fine. Is there a way to set the darkenss of the copy. When trying to copy with feeder it flashes the arrow and will not take paper through.
you must clean up your optical unit,AE sensor and blank exposure unit,enter the service mode and adjust the AE light,Primary and IP ofst (all this must do by specialist)
Mar 06, 2011 | Canon NP 6230 Copier
Paper is black.
Hello sir ; When you make a copy, lift up the glass cover , watch the exposure lamp is on or the light is wick, if answer is yes, replace exposure lamp, if not ,could be the HV power supply board got problem.
Oct 09, 2009 | Toshiba Office Equipment & Supplies
Makes only black copies.
Hello sir; when you make a copy open the cover then yo can see does the exposure lamp is on if not replace it.
Aug 23, 2009 | Minolta Office Equipment & Supplies
Copy does not work...did bulb burn out?
your printer is the problem not undrstand because when u print to computer then is print ok? if you are ok . you change your scaner lamp or clean mirror
Jun 29, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Xerox Copycentre C123 Creating a Ghost Image
First place an original on glass and make a copy -- mark #1. With that same original on the glass, move the exposure all the way light and make a copy -- mark #2. Again with the same original on the glass, move the exposure all the way dark and make a copy --- mark #3. Place #1 in the middle so the the copies read --- #2, #1, #3. The #2 should be the lightest and #3 being the darkest. If #2 is darker than #3 you have a developer problem and you need to call for service. If #1 and #2 are bad and #3 is a good copy your machine probably just needs a good cleaning, mainly the optics and charge units. If all 3 copies are still poor with the speckles, your are looking at the PCU ( photo conductive unit) also called the drum unit. You can order this unit online -- it is a customer replaceable item.
Jan 04, 2009 | Xerox CopyCentre C123 Black and White...
When we copy on our 4750e fax it comes out with black page
Can you see light from the scanner unit with you make a copy or try to send out faxes? The bulb for the scanner may be burnt. You might be able to find a replacement bulb, search google or contact Brother.
Jun 16, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
My copier won't print.
Are you sure that your scanner bulb is working. You may hear the scanner moving but the bulb may be burned out which will cause you to get blank pages.
Inkworks
May 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Toshiba 1370 Black and White Copier Logo
61 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
