Question about Polaroid TLA-01511C 15 in. LCD Television
Directv remote I have not been able to find a code to allow me to control the on/off switch and volume on the tv by the Directv remote. The tv is a Polaroid TLA 01511C, LCD. The Directv remote is model RC32. Any suggestions? Thanks
Someone told me the code was 10178 but it didn't work. I tried 0178 that worked for me.
Posted on Apr 30, 2008
I had the same problem
Use code #11523, it worked for both my polaroid tv's
Posted on Apr 14, 2008
    Problem Solver:
  • 14 Answers
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Posted on Feb 17, 2008
Direct tv remote to visio tv
I can help you with your Vizio TV & DirecTV remote control.
This is a list of all the Vizio TV control codes for DIrecTV remote controls:
11758, 10864, 10885, 11499, & 11756.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
May 13, 2010 | Universal Remote Control DIRECTV Universal...
Tip
DirecTV Remote Control Code Search Tosearch for a control code for your TV...
Tosearch for a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Slide the MODE switch to the TV position.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by 1:
  5. Aim the remote at your TV and press the PWR key once.
  6. Point the remote at the TV or component and press
    CHAN ^. Repeatedly press CHAN ^ until the TV turns off.
  7. When the TV turns off, press and release the SELECT key.
You have programmed your DirecTV remote control for your LCD TV.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
Tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
Apr 23, 2010 | Toshiba 24AF42 24" TV
RCA REMOTE CODE FOR DIRECT TV
If you contact DirecTV they will give you every RCA remote code they have for RCA. They can also telll you how to have the remote scan for every code that is stored in the remote you have. However, if your remote still won't control your TV, unfortunately there won't be anything you can do except use two remotes; one for the TV's power and volume; and the DirecTV remote for channels, guides, and everything else. Call DirecTV and choose tech support.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 04, 2009 | Universal Remote Control DIRECTV Universal...
I have a Directv RC24 remote control. I am trying
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Remote for DirecTV wont control my Toshiba VCR/DVD combo unit
Its true sorry but there isnt any codes available for combos.
Feb 19, 2008 | Directv D10 DTV Receiver
Trying to set my Directv remote to control my Orion TV........
Orion code is 11911 and to program your tv to work with a directv remote then follow these...
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Slide the "Mode Switch" back to Directv and try adjusting volume and turning tv and receiver off using the off button and then back on with the on button just above the off button
  • Dec 28, 2007 | Orion1934 19" TV
    Polaroid TLA-01511C 15 in. LCD Television Logo
    673 people viewed this question
    Top Polaroid Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
