Question about Bosch 24 in. SGE09A25 Built-in Dishwasher
Dishwasher draining - Bosch SGV4313GB/17
Before I start stripping my dishwasher,I was wondering was there any common problems with the Bosch dishwasher...mine is not draining??
  • 2 more comments
  • Anonymous Mar 13, 2014
    Bosch dishwasher will not drain the water out of the dishwasher
    unit will not drain the water out of the machine
  • Anonymous Mar 24, 2014
    Bosch Dishwasher SHE4AM02UC/01 won't sanatize
  • Anonymous Mar 28, 2014
    how do I reset programme
  • 833 Answers
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
I have a bosch dishwasher #SHU46C13UC it will not drain to well
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 21, 2011 | Bosch Dishwashers
Hi, I have an BOSH dishwasher SGV4313gb/17. It is about 8yrs old and has worked fine until last week when it did not complete its cycle. Have reset and it seems to complete cycle but I don't think it...
Are you using a rinse aid? if so and teh dishes are still not drying properly, try adjusting the setting for the rinse aid dispenser. Open the door of the dishwasher, open the flap where you pour in the rinse aid and look for the cirlce with the arrow and nunbers on it. If it is set low (1 or 2) try turning the arrow to a higher number. If that adjustment doesn't work, increase again and again until the dishes are dry.
Jan 05, 2011 | Bosch Dishwashers
Water in Dishwasher Bottom
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
May 04, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher won't drain model SHU3302uc/17
probably something stuckin drain pump. remove plastic part in bottom of unit with a torc screw driver spin the propeller and your problemis solved. let me know if it works.:]
Dec 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water not draining
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Sep 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
how do you disconnect the waste pipe from the back of a Bosch hydrosensor dishwasher
Aug 09, 2008 | Dishwashers
Open Questions:
Bosch 24 in. SGE09A25 Built-in Dishwasher Logo
1,317 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
