When trying to upgrade my Linksys BEFW11S4 with the latest firmware
(befw11s4_v4_v1[1].52.02_000_FCC_code) the upgrade stopped at about 75% on the status bar, on the page it shows upgrading on the top right corner. I've tried to download another firmware but it will not let me, it says it is still upgrading. This went on for about an hour. Can't connect to the internet with my other computers.
SOURCE: Charter High-Speed Cable and the BEFW11S4 Version 4
To resolve this problem, you will need to upgrade your router's firmware. Click ftp://ftp.linksys.com/pub/network/befw11s4_v4_v1.50.14_code.bin and download the file to your Desktop or My Documents folder (the link is to v1.50.14 firmware code). Once the BIN file has been downloaded, follow these instructions to upgrade the router's firmware: NOTE: Before upgrading your router's firmware, please make sure that the procedure is being performed by a computer that is connected directly to the Router with an Ethernet cable and not a wirelessly connected computer. Accessing the Router's Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Upgrading the Router From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. Click on the Administration tab. 2. When the ?Administration? page loads, click on the Firmware Upgrade sub-tab. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. If the logo matches the image above ("Linksys"), follow these steps: 1. Click on the Help tab. 2. When the "Help" page loads, click on the Upgrade Firmware link. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. After completing the steps above, the router's firmware should be upgraded successfully.
SOURCE: Setting up Wireless Security ? BEFW11S4
Securing your wireless network is a simple process, which generally does not require a lot of time. Please follow these instructions to secure your wireless network. Accessing the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 2. When "Internet Explorer" opens type http://192.168.1.1into the "Address" bar and click on Go 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK Setup Page Security Options When you arrive at the Setup page, you'll see the bulk of your wireless security features. There are three things you're going to want to set on this page: 1. SSID a) Delete linksys from the "SSID" field b) Input your own unique SSID. We general recommend something easy to remember, but secure enough to where people would not be able to guess it easily. Sometimes your best bet is to use your last name and add some numbers. a) Click Apply then Continue 1. SSID Broadcast (Firmware 1.42.7 and above only) a) Click No on the Allow "Broadcast" SSID to associate? b) Click Apply then Continue 2. WEP a) Click Mandatory for the "WEP" Option b) Click the WEP Key Settings button c) When the "Wep Key Settings" Window appears, change the option from 64 to 128* NOTE: 128 bit WEP may not work on non-Linksys products due to its lack of an IEEE standard d) Enter a passphrase** that is different from the SSID. Try to make it alphanumeric; instead of password, use password5532. Once the key has been Generated copy the key into a notepad document and copy that file onto a floppy. **NOTE: The passphrase will not work with non-Linksys products, so you will need to use the passphrase that you copied onto floppy. e) Click Apply then Continue f) Close the window g) Click Apply then Continue on the setup page. Setting up Station MAC Filter The Station MAC Filter option is a very good security feature that has been added to Firmware 1.42.7 and above. This option denies all wireless clients except those listed. To implement this feature please follow these instructions: 1. From the "Setup" page, click Advanced 2. When the "Filters" page opens, click on the Wireless tab 3. Make sure all wireless computers are setup to the router, and are currently able to access the internet. Once this is done, click on the Active MAC Table button. 4. Move the "Wireless Active MAC Table" window and click on Edit MAC Filter Settings on the main window. 5. When the "Wireless Group MAC Table" opens, go to the task bar and click on the Wireless Active MAC Table so that window appears. 6. With the two windows side by side enter the MAC Addresses from the "Wireless Active MAC Table" window into the Wireless Group MAC Table. - NOTE: When you enter the MAC Addresses do not include the dashes, and do not click "Filter" 7. Click Apply then Continue in the "Wireless Group MAC Table" window. 8. Close the "Wireless Group MAC Table" window and the "Wireless Active MAC Table" window 9. On the Main window Enable the Station MAC Filter setting.
I've tried doing that and nothing happened. I cannot get into the router's default address thru the internet. I did ping the router's address 192.168.1.1 and all I got was error code 5 on all four of them. So know I think I'm giving up and buying another router. I've been messing with this one since Saturday.
