LCW-0120 Labtec speaker polarity
I just bought an adapter for my speakers so I can hook it up to my computer. The instructions with the adapter said I need to know the polarity of the speakers. are the LCW-0120 speakers negative or positive polarity
    Scholar:
  • 84 Answers
I am assuming that you already know which wires go to which speaker and all you need to know is which one is negative and which one is positive. Here is one way to find out. If you can access the speakers at all or at least see the cones, it will be easy.
Take a small 1.5v battery and connect it to the wires in question, connect one end to the positive(+) and the other to the negative (-) side of the battery, don't do it for a long time, just enough to observe movement on the speaker cones. Observe the cones of the speakers, if the cones get pushed or moves out, take note of the polarity of the battery because now you know which is which. Now if the cones, move inward or it gets sucked in when you apply voltage, then it's backwards.
Posted on Feb 11, 2008
Hiw many mA does the adapter for labtec lcs150 speakers need
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
You want to make sure the plug at the speaker end is wired properly: + on the outer barrel and minus on the center pin (the adapter will have a little graphic for verification purposes). If so, your 500ma adapter should work fine. The voltage might be a little high but nothing the speakers cannot handle I would think.
Mar 29, 2013 | Labtec LCS 150 Computer Speakers
I need to know the voltage of the speaker for ac adapter matching
The speakers may have a label that has the voltage printed on it.
You can check the Bose WEB site for the specs of your model speakers. You need to know the polarity of the connector, if you get it wrong you could destroy your speakers.
You may need to contact Bose support if the specs do not help you.
Jun 14, 2012 | Bose Companion 2 Computer Speakers
What is rating of Spin 50 Power Module. Lost mine
Should it be a power supply that outputs AC and converts to DC inside the speaker case, or is it a wall adapter the outputs DC straight to the built in amplifier?
Some speakers have the voltage and polarity for the plug on the back of the speaker where the power lead plugs in. As they are only small speakers of probably a couple of watts it may only need about 2 Amps or less. Higher current is fine as the amp will only use what it needs to work correctly but I would'nt go below 2 Amps.
May 06, 2012 | Labtec Spin 50 Computer Speakers
I just need to know the specs on an AC adapter for my old Labteck SS-100 speakers. I want to buy a generic AC Adapter at Radio Shack and they suggested that I contact Tech Support.
i do not see a reason of wastig money on that venture as these speakers were not that hot when first made, humming noise from them was most annoying "feature"... but...
labtec ad-4 adapter was used in them, and output was 6vdc, 400ma, plug was 5.5mm x 2.1 mm with negative centre, if i recall, there was compartment in them for 4 "d" size batteries as well.
if you find this advice helpful, please do not hesitate to leave your recommendation and vote for me, thanx!
Jul 31, 2010 | Labtec SS-100 Computer Speakers
Well our speakers are not working can you show us how to install them
Hi there , You need to insert the Green Labled Cable from the Speakers into the green labeled Input jack in the Motherboard...Make sure you have installed your Drivers that came with your Sound Card or motherboard...Hope this helps bud
Happy new Year
Dec 30, 2009 | Labtec LCW 1060SEWN Computer Speakers
What is the polarity of the jbl platinum series speakers
Speakers don't really have Polarity ... they have Phase. The audiophile wants the speaker cone acting in the same direction not opposite directions. So, watch your wire - one conductor will have a rib on it, the other smooth. You pick which you want to hook to the red or the + or what the mark is on your devices pick the other conductor for the other side, black or - or what ever matches.
Make sense???
Please post comment to this question if you need more info
thanks for your interest in FixYa.com
please vote
thank s
a
Dec 07, 2009 | HP JBL Platinum Computer Speakers
I just hooked up my Labtec LCS-2420 speakers to my new computer and can't get any sound out of them. I can get the cheap ones that came with the computer to work, but not the Labtec. I hooked them up to...
if its a 6 channel connection its a little tricky try reconnecting your speakers that has a green connections. try playing a music while troubleshooting the connection...hope this helps..ITTech7574
Aug 29, 2009 | Labtec LCS 2420 Computer Speakers
No wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
Jun 21, 2009 | Labtec LCS 3210 Computer Speakers
Labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
Feb 07, 2009 | Labtec Spin 70 Computer Speakers
397 people viewed this question
 Grubhead
Grubhead
