Question about KitchenAid KSM150PS Artisan Series Stand Mixer
KitchenAid Mixer Squeaking
I ahve a KitchenAid mixer, Artisan. It squeaks a lot when the beaters are turning. How do I oil it. I can't see any easy way.
REgards,
Tony
  • Anonymous Mar 27, 2014
    Shows a number 10 but only 6 slots and speeds on my kitchenaid artisan mixer
    Problem Solver:
  • 12 Answers
I would first get some canned air. Spray out the area around the Shaft. This is to make sure no harden food is up there. After that is clean spray some cooking spray "PAM"in the Shaft area. This should help. Good Luck
Posted on Feb 11, 2008
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
I cannot remove the mixer attachment from the mixer. It will not move, or twist to the side to release.
Use a small amount of vegetable oil to lubricate the beater shaft and
the beater. Slightly tap the beater up and sideways with a rubber mallet
until you can move the beater easily along the shaft.
Jul 31, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
I have oil leaking from the beater shaft. a lot
TRY REPLACING GREASE IN GEARBOX AND MAKE SURE YOUR FELT COVER IS IN PLACE (AND CLEAN) THAT SITS UNDER GEARBOX.
**** KENWOODCHEFUSEDMIXERSANDSPARES
Jan 05, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
The beater won't come off of the mixer. Kay
pour a little cooking oil in beater socket and wiggle it_Ned_
Nov 02, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
The beater won't come off of the mixer. cheri
Cheri;
I like the name. Anyway, pour a little wesson oil in the socket of the beater and wiggle it, then try again. Good Luck _Ned_
The flat beater is stuck in the mixer and I can't remove it.
oh yes you can.:) pur some wesson oil into the sockets the beaters go into and a little around the button.. Let set a few minutes and work the beaters back and forth as you pull gently. Make sure it is unplugged!!!!!
Oct 27, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Theres a loud squeaking noise when the mixer turned on
Hi. These mixers normaly make a lot of noise when in operation. Go to the shop that sold it to you, or any place that has these units on display and ask them to turn on the mixer for a demonstration. If their mixer does not make the same noise, then contact Kitchenaid Customer Service and ask for a replacement under warranty. If this solution assists you, please rate it. Good luck! ricardok45
Mar 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
HOW DO YOU GET THE SQUEAKING NOISE TO STOP
You must indicate where the squeaking is coming from. If its only squeaking, move on. There's other people here with down time problems. It'll stop squeaking or stop running eventually. If it stops working, then write in!
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Sep 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
2,795 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
