Question about Motorola Mobility RAZR V3
RAZR ringer (speaker) doesn't work
My RAZR only works on vibrate. There is no sound for the ring tones at any ringer volume setting and the speaker phone doesn't work? Any help would be appreciated.
  • wwchevy Feb 14, 2008
    Fixed it. The speaker was not making electrical contact. Replaced it and now it works great.
  • 983 Answers
The speaker inside the phone is in mis contact or it is dead .. try changing the new speakers into it ... it will work ...
if u are not gud at servicing then visit the technician........
Posted on Feb 11, 2008
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Pebble ringer inop
Does it have a speakerphone function, does that work? It would seem that the second speaker is malfunctioning. There is usually seperate speakers for the earpeice and for the rigner/speakerphone. You could open the phone and make sure the speaker is sitting correctly, it could have rotated off it's contacts. But you may have to replace the speaker, possible found on eBay.
Mar 20, 2008 | Motorola Mobility PEBL U6 Cellular Phone
The ringer is silent
Possible that the speaker has worn out and so does not ring. Try and check the ringer settings after opening menu , settings and tones.
If the ringer volume is kept at the highest without any sound then the speaker could have failed. Check to confirm the circuit trigger with the ******** set instead and if this works the ringer needs a replacement.
May 06, 2011 | Cell Phones
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
I have just been given a RAZR phone as my old phone didnt like going for a swim. I have set the ring tone and I can hear it. the volume is set as high as it will go and I can hear the sound as I adjust it....
The problem you are experiencing is that your ringer/speaker is faulty,
The ringer/speaker is what sounds out when your phone is called or you receive a text message
The only solution is to have it changed
Problem solved!!
Thank you for visiting fixya
Feb 23, 2010 | Orange MOTO RAZR V3x GSM Mobile Phone...
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Feb 10, 2009 | Motorola Mobility RAZR V3
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
398 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
