Question about HP Compaq Presario V2000 Notebook
Firewall settings when i try to log onto the internet and msn it wont always allow me to do this it is becoming more of a problem saying check firewall settings on your computer can you help
  • James Harbidge
    James Harbidge May 11, 2010
    Can you tell us...
    1. What operating system?
    2. What version of Internet Explorer?
    3. What firewall software do you have? Norton / Mcaffee etc?
    4. Same with AV Software...
    5. Have you updated the PC lately using windows update?
    Thanks
    James
    www.small-biz.it
  • 54 Answers
First you disable the windows firewall then you check the internet.
Posted on Feb 16, 2008
Error 80072f7d
Since you can't immediately login, remember that you can try logging into the Web Messenger,
at least until you can restore your normal Messenger functionality:
http://webmessenger.msn.com
However, here are some suggestions you should check/try if you haven't already.
1. The date on your computer needs to be set properly -- double click the clock verify that
the time and date are set.
2. If your password information is not saved, verify that you are typing it in with the
correct case (uppercase or lowercase).
3. Change your password @ https://login.passport.com/ChangePW.srf to
something smaller (under 10-12 characters), then try signing in again.
4. If you use a firewall (like ZoneAlarm, Norton Internet Security etc. ), it's possible
that Messenger doesn't have the correct rights to access the Internet, especially since you
upgraded. You may need to re/add Messenger to the allowed list of programs in your firewall
if this is the case.
5. If you disabled your firewall in the past, it still may be blocking Messenger -- try
restarting it and see if that helps the situation. You also might try uninstalling an
installed firewall, to verify that it isn't causing a problem (even if it is disabled).
6. Clear your IE cache and cookies -- open Internet Explorer, click the Tools menu, then
Internet Options, then click the Delete Files button, and when that's complete click the
Delete Cookies button.
7. Check your IE Security settings -- open Internet Explorer, click the Tools menu, then
Internet Options, then Advanced tab, scroll to the Security section, and verify that "Check
for server certificate revocation" is unchecked. Also verify that 'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
8. Click Start, then Run, and enter the following:
regsvr32 softpub.dll
then click OK
and do the same for the following:
regsvr32 wintrust.dll
regsvr32 initpki.dll
regsvr32 MSXML3.dll
Nov 21, 2010 | Microsoft MSN Messenger Connect Service
Error code 8007ee7
hi,
Possible solution
  • The most likely cause for this problem is that your firewall does not allow MSN Messenger to access the Internet. This happens often if you install a new version of Messenger. Make sure MSN Messenger is allowed access in your firewall rules.
  • This error might also be occuring because there is a proxy server enabled in MSN Messenger while you do not use one. To remove the proxy settings, click the "Tools" menu and then "Options..." at your MSN Messenger main window. Then in the options screen click "Connection" in the list to the left. Next, click the "Advanced Settings..." button. You can try and uncheck all checkboxes in this screen except the one labeled "TCP" to let MSN Messenger connect through a direct connection. If that does not work you can restore the settings again by checking the boxes you unchecked before.
Oct 04, 2010 | Microsoft Windows Live Messanger
I am trying to sign on to msn messenger and i get the error code it is 80048820
Please follow steps to resolved issue
The Solutions to MSN Error Code 8004882080048820_lan.jpg Internet Explorer - Try removing the tick next to Internet Explorer 'Proxy server' settings, instead, go with the 'Automatically detect settings'.
1) Launch Internet Explorer, click Tools and then click Internet Options.
From the Internet Options dialog box, go to the Connections tab.
Click LAN Setting. Un check the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) checkbox. Finally positively tick: 'Automatically detect settings'.
2) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger. See also Error code 81000314
3) If necessary, logon as a local administrator and set the computer's clock to the correct date and time. (Check on the internet if possible.)
4) Turn off the firewall temporarily. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
NetGear problem, but also with some other routers
a) Enter IP address 192.168.0.1 in your browser's address bar.
b) Log on with ISP user name and password.
c) Enter Admin, password
d) Navigate to advanced menu, WAN set-up
e) Change MTU size to 1400
5) Try a password of no more than 8 characters.
6) If you are using IE 7.0 check the SSL Settings. Internet options advanced (Tab) scroll down to the bottom. Security section. Tick 'Use ssl 2.0'.
7) One of the simplest ways of curing MSN error 80048820 is to unplug, or restart your modem. This is particularly effective for cable modems.
8) We should have tried this solution before; check that the MSN site is 'up' 'available'. However, even if the site is down, you don't usually get error code 80048820.
8a) As a variation, of checking online, you could try phoning your local Microsoft Support office. Local area numbers available from http://support.microsoft.com.
9) Have you just installed any anti-virus software? Did the anti-virus software just make a big update? Try disabling and see if that cures the error.
10) A drastic solution is to try uninstalling MSN Messenger version 8.0 or 7.5 and install Microsoft MSN version 7.0.
Hope it can resolved issue
Thanks for using Fixya
Apr 02, 2010 | Microsoft MSN Messenger Connect Service
I can't log into msn..says errore porta..net messenger service non attiva..dice che sono connessa a una rete cablata,please help me
It sounds as tho your firewall is blocking the service. Go into your firewall, you will find a list of allowed programs, and simply click on allow, for MSN. BTW, MSN uses port 1863
Nov 16, 2009 | Microsoft Windows Xp Home Edition Sp2...
Unable to install yahoo msn
Check your internet connection, may be your connection encountered problems...always download from your trustful sources website. i think better you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you download yahoo messenger,check it out, may be it blocked your yahoo messenger set up from downloading it.
Try these! Good Luck!!
May 31, 2009 | Yahoo Messenger
Crystal eye webcam for my acer aspire 5735 wont work on msn
Adjust your browser security setting to allow webcams if you have flash micro media you will see the camra security but if you go to internet setting you can ajust the broswer setting from there .make sure that your firewall allow your webcam .then let me know how you did
Mar 25, 2009 | Acer Aspire 5735 Notebook
Msn wont let me sign in under error code 80048820.
Since you can't immediately login, remember that you can try logging into the Web Messenger ,
then click OK
regsvr32 MSXML3.dll
Sep 26, 2008 | Computers & Internet
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Yahoo messenger,msn messenger
you will need to log onto a user with administrative properties then get into the firewall that is blocking access to these programs from the internet and allow them full access.
Sep 09, 2007 | Microsoft Windows XP Professional for PC
HP Compaq Presario V2000 Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
