Question about Maytag Neptune MDG9700A Gas Dryer
Will not heat up
The dryer will not heat up everything else is working prior to this it had been taking a long time to dry
  • 3 more comments
  • Linda Bramer-Holman Apr 08, 2008
    Same thing on my DE713 Maytag. Checked all the connections I could see and replaced the inside tub sensor.
  • Anonymous Jun 10, 2008
    The dryer is not heating up at all, everything else seems to be working. No heat!
  • Anonymous Nov 15, 2008
    LDG7500AAW will not heat up
  • Anonymous Jan 02, 2009
    all systems function except no heat and do not hear a gas ignition. checked ducting and vents. no obstruction to air flow. affirmed gas flow to house and fau units functioning normally. 01/02/2009
  • robert samples May 11, 2010
    are you hearing the burner ignight after about 30 seconds
DE713 is an electric Dryer
Posted on Apr 08, 2008
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
My dryer does everything it is supposed to do except fully dry the clothes. I took the back off and cleaned everything. I even pulled the heating element out and made sure all the coils were heating up. It...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Sep 03, 2010 | Estate TEDS840JQ Electric Dryer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Does not dry clothes, keeps turning off prior to
then it maybe the heat element.Is it getting hot and it may be the controll panel,there still could be sme lint stock some were,try using vacum hose and put in back of dryer it may free it up.
Jul 08, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Take long time for dryer to dry
If your dryer is STILL heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to consider before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Mar 31, 2010 | Whirlpool ET8CHEXSQ Dryer
Frigidaire Front Load Dryer Model # leq2152eeo Problem: it is not drying the clothes. The dryer heats up and everything else is working, except it takes 4 cycles to dry something that should have dried...
while the dryer is running.go to the outside of the house and check the air flow,there should be a large amount air being blown out if there is not check the vent and ducting for lint build up and make sure the hose is not kinked.
when there is restricted air flow all the warm moist air will stay in side the dryer causing the clothes to take a long time to dry. i hope this helps you with your dryer
Jan 24, 2010 | Dryers
LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Aug 25, 2009 | LG DLE2512W Electric Dryer
Dryer takes 3-4 cycles to dry clothes
Hi first are you sure your heating element is good and working is the dryer getting hot in side when you open door to check clothes.if they are and you are sure the duct work is clear and no clogs, you might try this I have heard this from other people take your lint filter out and wash good with hot soapy water they say that after so long using dryer sheets this filter can get a invisible coating on it.
Hold the filter under water and see if it will holds water I know it sounds crazy but I have heard it from more than one source.
Dec 09, 2008 | Whirlpool GEQ9800P Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Maytag Neptune MDG9700A Gas Dryer Logo
149 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
