Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Tv Shuts off occasionally 1min upon power up shows red lamp light
About two months ago I replaced the lamp and everything has been fine uptill now. when you turn the tv on the sounds comes on but now picture. Then after about a minute or two the TV shuts down and displays a red lamp light. (This only happens occationally. Sometimes the TV powers up fine and runs great.)
The replacement bulb was a different part number than on the back of the tv, but was supposed to fit my tv so the store said. When I received the bulb it was only the bulb and didn't come with the housing. I removed the old lamp from the original housing and installed the new bulb in the old housing.
I have been reading about different arc lengths could this be my problem or is it a ballast problem, or is it just a bad lamp?
What is the ballast and where is it located? Is it something I can change myself?
Thanks,
Ross
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 11, 2008
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Jvc projection will not work
May be a fan failure. Mine did the same thing a couple of times. i unplugged the tv, cleaned the cooling fan and plugged back in..the tv worked fine after that.
Apr 20, 2010 | JVC TS-CL110UAA Projector Lamp
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Zenith HD 44 inchr red lamp light is on
sir,,,maybe,,,,,but you said your tv is ok soo i think its just alright,,,thnkss
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Televison shuts makes a sound and shuts off repeatedly
Probably needs an original SONY lamp instead of the "replacement" lamp you put in.
Dec 23, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
392 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
