Question about Refrigerators
In operative water dispenser.
GSS25WGPA BB GE side by side. Changed filter. Ice maker and dispencer work fine. No water through the water dispenser. Filter re-set flashes red for 3 sceonds but no green light. When water dispenser tab is pressed, you can hear a click or activation at the rear of the refrigerator. Removed new filter and it was full of water and was reinstalled. Still have the exact same conditions as listed above.
  • 4 more comments
  • Anonymous Feb 12, 2008
    ge water filter it's geetting loose,it wont hold, no water caming from dispanser!
  • Drinkwalter Feb 13, 2008
    Drinkwalter response to TECH 17:
    Held the dispenser paddle down for more than a minute on several different times but no water. Also the filter reset same condition. I changed the filter because the old one had been in service for 1.5 years. It was still working fine. Thanks.
  • arktenn Feb 21, 2008
    I am having the same problem! The ice comes out fine, but the water dispenser will not work. press the paddle and a click, but no water. Tried the defrosing thing....did not work. Is there an electronic switch board or something that could be bad?
  • GhiaGrrl Mar 02, 2008
    I am having the same exact problem (no water dispensing)... looking at the "Freezer" and "Fresh Food" settings, what is recommended??
  • starkrats Jan 21, 2009
    Ran into same problem. Did exactly the same thing as "haregopal" and disconnected water line behind the bottom grill and it works down there. Conclusion: frozen water line somewhere in the freezer door. Going to try running the freezer at the warmest temp and see if it thaws.
  • robert samples May 11, 2010
    try holding down the water disp paddle for one min let me know what happens hold down the filter reset for about 3-6sec to reset but its just a light wont affect anything and did you change the filter because of the light or because you stopped getting water
I have GE side by side refrigerator - 2004 model GSH25SGRB SS. From the blog I found out the problem is with frozen water line. If I keep the door water would dispense ( thawing). Or if you disconnect at the bottom ( take the grill out and disconnect) the water would dispense.
I placed a call to GE. The service person came. He said GE could fix with a 3 watt heater. He opened the panel. Pasted a heater. It came in a Y shape form. He connected that to the internal wiring. After some time the water started working.
Part $40. Labor for 15 min work = $210. Total = $250.
This is really should be a recall case. No part broken. They had to design a heater to solve this problem. What a rediculus thing is this. I am trying to call GE and ask to refund.
What a cheat GE!!. F them.
Posted on Jan 07, 2009
Defrost manually how?
Posted on Mar 04, 2008
  • 958 Answers
Could be a frozen water lines. try defrosting it manually and check again for water after defrosting. water lines that gets too cold froze the water inside hindering the flow of water.
Posted on Feb 13, 2008
Why is it not dispensing water?
Do you have a dual water inlet solenoid valve ? If so one side might be faulity.
Apr 27, 2014 | GE Refrigerators
I have a refrigerator that uses the GE SMART filter. When the filter needs to be changed, the water stops working. I changed the filter -- still no water, yet it makes ICE....any thoughts?
The water valve has two sides. One side is for the ice maker and one side is for the dispenser. If the dispenser side fails you have to change the complete dual water control valve. What is the model number of your GE Refrigerator? Sea Breeze
Jan 10, 2013 | GE Refrigerators
GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
Ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
984 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
