Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Same old PFM-42B1 problem - is it worth the $ to fix?
I have a Sony PFM-42B1 monitor that someone recently gave me with the dreaded "6 flash" problem. If I turn it on, the monitor springs to life with a "staticky" screen(no video in connected to it yet, I'm missing a cable), much like any TV without a signal. Then, about 1/2 to 1 sec. later the fans turn off and it shuts down. It restarts again(it does this 4 times) with the same results, and the status light flashes numerous times(I counted roughly 6 between 2 quick double flashes). Now, can this be fixed, or any component replaced? I popped the back off on the hope I'd see some IC burned up, which I might be able to replace, but everything looks fine. It's amost as if the circuitry is getting a false "shutdown" signal after it boots up.
I've seen a bunch of "quasi" explanations for this but nothing definitive. Can anyone help?
  • Anonymous Apr 23, 2008
    Haveing the same problems.
  • Simone_Italy Jul 14, 2008
    I've the same problem but no IC burned, nothing burned inside. Maybe only X&Y SUS damaged?
If you call sony technical support they will send you a shipping box to ship the unit to them they will then repair it and ship it back to you. I've had mine back for a year and it works great!
By the way this was done at no cost to me. Manufacturing issue.
Posted on Aug 21, 2008
Pleas check this if you have a problem like this.
Remove the back cover. then look at het left top corner ther is a flat cable to the screen .. ( sometimes an cover is on the cable )
ther ar some black square areas .. moste of the time the black square is damaged...
Repair is not posible...
Best regards ....
Kruutje
Posted on Mar 22, 2008
  • 20 Answers
Ok to clear everyones issue on the 6 Flash fault.
If the tv powers up with a flicker of the screen and repeats this 3 times then shuts down the Plasma Panel (PDP) has died and only a replacement panel will cure this problem. This is getting a common fault now due to the age of these sets although they do still give good results. One more thing if you decide to be brave and buy a 2nd hand panel dont repeat DONT just think you can unplug it and plug the other panel in as you can't due to voltages from the power supply to the screen are set preset to the panel - You must set the voltages on the power supply to match the panel ( usually on a sticker on the PDP panel). I hope this clears lots of 6 Flash issues up.
Posted on Sep 06, 2008
How do you change fan on Sony PFM 42B1 monitor
Download the service manual to this set. It will have all details with illustrations. To download it , click here.
Jun 05, 2012 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Tip
SONY PFM-42B1E FLASHING ERROR CODES
Ok i have here the problems that occur when the red standby led flashes on these sets which is an error code.
2 FLASHES ( PAUSE ) 2 FLASHES = X SUS TEMP (DD CON)
3 FLASHES ( PAUSE ) 3 FLASHES = Y SUS TEMP (I/O BLOCK)
4 FLASHES ( PAUSE ) 4 FLASHES = CENTRE TEMP
5 FLASHES ( PAUSE ) 5 FLASHES = DIGITAL 5VOLT
6 FLASHES ( PAUSE ) 6 FLASHES = PDP PANEL FAULTY
I hope that helps you cheers.
on Nov 11, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
PFM 42B1 [HELP]
Count the flashes - This is an error code - Usually between 1 and 6 flashes followed by a pause.
Aug 30, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Pfm-42b1
Please read my other posts to this answer - 6 Flashes means the plasma panel is dead.
Aug 29, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-42B1
Your PDP panel is duff - Only a replacement will repair.
Jul 16, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
PFM-42B1 VGA picture is very wavy
Sounds like the logic board. Is it the same on all inputs ?
May 21, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
My sony FLASHES 4 times
STBY LED flashes
2 times pcb X SUS TEMP (DD CON
3 times pcb Y SUS TEMP (I/O Block)
4 times Center TEMP
5 times Digital 5 volts
6 times PANEL FAIL (PDP)
try unplugging it for a while, from other forums looks like they sent them back to sony for repair
Dec 10, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
609 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
