Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Whirlpool ARC7470AL FRIDGE FREEZER
I have a whirlpool ARC7470AL FRIDGE FREEZER, currently it has been getting cold and then loses tempreture, when i turn the thermosat it get cold again and then the same thing happens , i have cleaned the back of the fridge and still the problem is there
could you help me
  • moseley1 Feb 11, 2008
    it is a frost free freezer, when the thermostat is switched higher the fan works and the fridge and the freezer work ok but only for a day and then i ahave to turn the thermostat off and on again
  • robert samples May 11, 2010
    do you hear the fan running in the freezer and do you see frost on the back wall of the freezer
    President:
  • 1,314 Answers
Ok you need to replace your thermostat its out of calibration or sticking
Posted on Feb 11, 2008
2 Suggested Answers
  • 1073 Answers
SOURCE: whirlpool ARC7470AL FRIDGE FREEZER
you have one of three problems and only one problem
the defrost timer is bad
the defrost heater is bad
the defrost thermastat is bad
only one of the above is the problem but no way to know without checking each part with and ohm meter
Posted on May 07, 2008
After defrosting, the freezer will not start. - Whirlpool fridge.
I presume that you still have got electricity power and the fuse has not 'blown' - if not you could try putting in a new fuse in the plug, sometimes two problems can occur simultaneously.
Otherwise I would leave the door shut to keep the stuff as cold as possible, some may refreeze, or ask a neighbour, friend, or relative to let me have some space in their freezer.
Aug 28, 2012 | Whirlpool Refrigerators
Freezer side is fine but fridge side wont get below 39 degrees
Nominal tempreture for your refrigerator is 36-38. on the Freezer the tmpreture should be between 0-2. One of the first things to check is on the freezer side is there any frost or snow build up on the rear wall of the freezer. If there were this is termed as a defrost issue. If you do have this issue with frost build up message me back and I will instruct you how to repair this issue. Another thing to check is if the evaporator fan inside the freezer is blowing the cold air into the refrigerator. The Freezer section is the only area that produces the cold tempreture a fan blows the cold air off the evaporator coils through a damper door that opens and closes depending on the tempreture the refrigerator side is set to. Also check the damper door for any ice build up as well this would cause the door not to open and close and remain in a stuck postion. This would cause inadequate tempreture in the refrigerator side as well. If you have any questions or need any schematics or step by step instructions message me back the model number of your unit and I will provide these and answer any further questions you may have. I await your reply
Thank you
Rick
Jul 12, 2012 | Frigidaire Refrigerators
Whirlpool fridge quit cooling
when you adjust the tempreture dial for the refrigerator this would turn on the evaporator fan motor located behind the rear wall of the freezer click this link http://c.searspartsdirect.com/lis_png/PLDM/00052094-00007.png part number 17 on the schematic would be the panel that you would remove when you remove this panel this would give you access to the evaporator coil as well as the evaporator fan motor if the fan is not spinning then you would replace the evaporator fan motor. If you see any ice build up on the evaporator coil or the fan motor or blocking the drain located under the evaporator coil this is termed as a defrost issue. If you find this then message me back and I will give further instruction on how to diagnose why your unit is haveing a defrost issue. The freezer is the only area that produces cold in a refrigerator. The evaporator fan motor blows the cold air through a small damper door that opens and closes depending on the tempreture inside the refrigerator. The first thing to check is the fan motor that is behind the panel that I mentioned. If you remove the panel and find that the fan is blowing and spinning message me back for further diagnosis. I await your reply Thank you
Rick
P.s what is the tempreture inside the freezer currently?
Oct 23, 2011 | Refrigerators
I have a whirlpool gold refrigerator model #GC5SHEXNS05, we had a bad storm the other night and it knocked off the breakers. well it turns out the fridge is not getting cold anymore, however the freezer is...
this solution is for the whirlpool gold refrigerator remove the rear panel inside the the freezer area and see if you have any ice build up on the evaporator coil if you do you will need a multimeter and have to perform tests on the defrost thermostat which is most likely your issue the defrost heater and the defrost timer or adaptive control board. while this rear panel is off also look at if the fan is running as well. The freezer area is the only part that gets cold in a refrigerator the cold air is then blown by this small fan through a door that is located in the back of your refrigerator the door is controled by a control located ini the ceiling of the refrigerator. The door opens and closes letting the cold air into the unit as needed to achiieve the desired tempreture you can also read more on this topic by clicking here http://www.applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm perform your continuity tests and message me back if you have any further issues or questions and please remember to rank how this opinion has helped it allows me to continue to help others in similar situations Thanks again Rick
Apr 29, 2011 | Hamilton Beach Water Cooler with Storage...
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Freezer wont defrost and fridge not cold
Better solution is to replace the defrost element,defrost timer,or defrost thermostat,one of these are not working and when replaced will fix the problem.
Aug 01, 2009 | Whirlpool GS6SHEXNL Side by Side...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
247 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
