Question about Vacuums
My old Tristar canister vac.
Unit was working perfectly until recently. It will no longer power on. The vac broom attachment come on so it is getting power threw the unit. Is there away to determine if it is just the switch or motor that has gone out. This vac is 16 years old.
  • 3 Answers
If you have a voltage meter you could see where the problem lies. All TriStar parts including the motors, both the nozzle head motor and the actual vacuum motor are purchaseable online through www.totalvac.com
I have ordered parts through them and everything arrives no problem and they are priced nicely by the way.
Posted on Feb 12, 2008
Dyson dc28 toubleshooting wand
Can you disconnect the hose from both ends of the unit?
I generally push a broom handle down a clogged hose, and second broom handle if needed!
You can also attach a shop vac hose to the shop vac exhaust and blow it out using the exhaust of the shop vac.
Maybe you sucked up a dryer sheet or plastic bag. Empty the unit completely and look at all the possible portals where items have to travel through.
Oct 17, 2013 | Vacuums
How to reverse suction
If you have another vacuum handy (such as a shop vac), put your shop vac hose onto the exhaust and direct it into your other vacuum. Some vacuums allow you attach something to the exhaust, but many have abandoned this very handy design feature. Sometimes a broom handle works too. Where in the hand unit is it stuck?
Jun 24, 2013 | Electrolux Centralux Vacuum
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
My vacuum is constantly shutting itself off. When
It sounds like you have a blockage somewhere and the air is not passing over the motor to keep it cool. There is usually a thermostat mounted either on or near the motor. The blockage can be anywhere from the elbow ( the swivel part of your carpet sweeper if you have a canister vac) up thru the hose.If you have a canister vac, use a broom handle to push through the hose to clear the blockage. DO NOT ! use a coat hanger or anything that will cut or tare the hose. There are electrical wires in it that have 120 volts and causes quite a shock !
If you have an upright vac, start with the duct hose that comes from the part with the brush up to the hose and on to the main canister of the vac
If this does not work, take your vac to a reputable vac shop for repair. Hope this helps,
Joe
Nov 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover Uh30010com the hose on the canister does not stay lock (it keeps poping out). I heard great reviews on this vacuum but I am so dispointed with the canister I am ready to return it to the store, I...
you can take it back. they will return it they know this happens all the time. If you like canistar vacs you should get a tristar. they are the best! call me for more info 866-635-9254 John
Nov 01, 2009 | Hoover Vacuums
Power's off when the canister is removed or locked in upright
you have a clog someware. you should invest in a tristar cleaner. cheep vacs dont have near enough power to get much more than the stuff ontop. i am a tristar authorized distributer,you can call me just to talk 866-635-9254 or go to tristarclean.com call me3 when you are ready to buy a tristar. John
Oct 19, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Kenmore vac producing burning odor
It sounds like you have bad carbon brushes on the motor. Get replacement brushes from a local vac shop, and take the unit apart. On each side of the motor their is a retangular piece of plastic with what looks like magnets in them. In most cases they are simply held by 2 screws. Replace these brushes and reasemble the unit. If the problem persists you have burned out the comutator on the motor and the whole thing must be replaced.
Apr 15, 2009 | Kenmore 22085 Bagged Canister Vacuum
How does it work?
Most units of this type make steam by heating water that is placed in a canister. Other than the place you attach the "hose", there should be only one other place on the body of the unit that opens up... that's most probably where the water goes in. Put water into a measuring cup, graduated cylinder, filling to known point. Then pour water into unit until 1/2" below fill hole. Note on measuring cup how much you used. This is the unit's capacity. Put "lid" or "cap" back on, plug unit into wall and wait a little while. Voila! Steam.
Mar 23, 2009 | Tristar SB Steam Buggy Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
127 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
