Question about Samsung SYNC SGH-A707 Cellular Phone
Changing black background color
Is there a way to change the black background on the menu settings screens?
  • jb707 Feb 11, 2008
    Thanks for the response. However, from things I have read, you can not change the themes. I was hoping someone had one of those nice codes that could hack into that aspect of the phone?
  • Anonymous Mar 29, 2014
    i can go into settings and change it to plum instead of this ungodly yellow and it wont budge
  • 983 Answers
Download the themes from net and then install it......................
Posted on Feb 11, 2008
I have a black square on which my twitter profile information sits - how do I change the black background to something else?
If you want to upload your own background image or customize the sidebar and color scheme of your page, follow the steps below.
  1. Sign in to your account.
  2. Go to your Settings and click on the Design tab.
  3. Scroll down to the Customize your own section.
  4. Click on Choose file to upload a background image. images justify to the top left of the screen. You cannot stretch your image to fit. It will display as the size you uploaded (file must be smaller than 2MB).
  5. Check the box to Tile background if you want your picture to repeat across the background.
  6. Choose whether your Background position will be left, center or right.
  7. If your image isn't very large, choose the background color that will show behind the image.
  8. Choose a color for links.
  9. Choose a black or white transparent overlay.
  10. Click Save changes.
Source: Customizing your profile design
Jan 09, 2014 | Computers & Internet
Tip
How to change your windows 8 Start menu background
1st go to the windows start menu,then go to the up right corner of the screen then a menu should come up,then select settings and then select personalization,then select a backround or use your backround on the desktop,stay on the background if you want a color only,select a color i you choose to stay on the background.Watch the video for more info
By Thedimond Gamer,About How to change your windows 8 Start menu background
on Aug 09, 2015 | Microsoft Windows 8.1 - Windows
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Change background from black to white
Which operating system ??
Is it for computer background or a program ??..
Make a Black Background White
The desktop appearance of a computer equipped with Microsoft Windows XP, whether PC or laptop, can be customized easily.
Users can change background color, background image, frame color, font size and the arrangement of desktop icons.
Five easy steps how to change the desktop background color from black to white.
Changing Background Color
Right-click the mouse on any open portion (i.e., non-icon) of the desktop, which will open a menu. Select "Properties" at the menu's bottom, which will open the "Display Properties" application.
Click the "Desktop" tab at the application's top.
Click the down arrow next to the "Color" button, and select the white color.
Click the "Apply" button, then click "OK" to close the application.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_background_color.mspx?mfr=true
Aug 30, 2013 | Computers & Internet
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
Menu green color
In your settings menu if your using an android phone go to display settingsLook for the wallpapers and choose the background that you want. Do the same thing on the message option settings so you can change the background.Hope this little info has helped you..have a good day.!!
Feb 19, 2012 | Samsung Stratosphere
How to change the color of the background?
This is pulled from the tutorial PDF:
================================ DESIGNING YOUR MENU Now that your content is added, you can customize the look and feel of your menu. You can change the background, title, and chapter button layout and text. Before changing your text, it's recommended that you set your background first. Often, the color of your text will be dependent on the background color. A good amount of contrast between the colors is necessary to ensure that the text stands out clearly ================================
The option to change the background is in the Themes tab.
Mar 02, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Hi how do i put a backround on my phone
Hello edgar_25_06,
Putting a background on the palm centro phone could either mean adding a background picture or changing the background color. If changing the color is is desired then its simple:
•Select the the 'System' category in the drop down menu at the top of the main screen.
•Open the Prefs application.
•Select 'Color theme' (near the bottom of the Prefs options).
The Color theme option displays a list of many different screen color settings. Each one of the color themes can be selected and tested on the centro until you find the one you like. Adding a picture for a background is a different matter. I haven't found out how to do that yet.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 18, 2009 | Palm Treo 500 Centro
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
Samsung SYNC SGH-A707 Cellular Phone Logo
112 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
