Question about Frigidaire FWS1339A Top Load Washer
FWS 747RFSI it won't drain. washed 1 small quilt, spins but was full of water when I woke up. I lowered the drain hose to roughly knee height and some of the water emptyed. Could it be the pump that pump water out or is drain clogged? Please this is urgent need help.
    President:
  • 1,314 Answers
Yes it is Ok you probably have something blocking your pump. Facing the washer take a thin but stiff putty knife come over from the edge of the washer about 2-4 inches and insert the knife you should feel a spring clip when you push in at the same time lift the top a little. Do that to both sides. Then take the two screws out of the bottom of the front panel slide it down then off. You will see a hose coming down from the tub to the pump if you have a wet vac remove the drain hose from the stand pipe and use the vac to pull the water out of the washer squeeze the hose up and down to see if any thing is in it. If you don't have a wet vac go to the auto parts store and get a pair of radiator hose clamp pliers and clamp the hose coming from the tub to the pump. Put down some towels and remove the hose from the pump .With a flashFWS 747RFSI - image2.gif light look in the pump to see if there is a foreign object jamming it or blocking it if any of the impeller blades or broken you will have to replace the pump then reassemble and if you used the hose clamps don't forget to remove them .let me know what you find
Posted on Feb 11, 2008
WHIRLPOOL Washer #LA5578XTW0 won't drain
Is the end of the hose where the water comes out into the sewage up at the top height of the machine? on some machines if it is lower than the top height (not lower or heigher but level with the top of the machine) it automatacally closes off the drain Flapper preventing the water from draining.
check the hose; disconnect the hose from the machine and take a deep breath and blow through the hose as hard as you can. if there is no obstruction, replace the hose ( bet there is a sock stuck in the drain hose).
with the drain hose off~check where it connects to the machine, some machines have a "flapper" that closes when the machine is in operation and opens when it drains. Unplug the machine, then see if the flapper is loose enough to open and close. Also check to see if something is stuck behind that "flapper" preventing it from opening to let the water drain.
Nov 10, 2016 | Whirlpool Washing Machines
When the timer reaches the spin cycle the water does not drain or spin. All other functions are working.
Hello Joe, thank you for your inquiry!
From what you have described your Frigidaire washer will not drain or spin. I would recommend checking on the drain hose to make sure it is not restricted or too long. Also check to make sure your drain hose is not too far down your drain pipe. If the drain hose is in good condition it might be a possible problem with your timer or drain pump. Since it could any one of those underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. -Matt
Dec 11, 2015 | Frigidaire FWS933FS Top Loading 3.0 cu.ft....
Water discharging from drain hose by itself while running washing machine, drain switch not functioning
It sounds like you have a simple syphon running. The end of the drain hose MUST be higher than half way up the height of the drum. If the hose is lower than this then physics is not on your side and water will simply fall out of the hose because the end is lower than the height of the water in the drum!
Sep 01, 2015 | Haier Washing Machines
Whirlpool Duet Sport Washer (model: wfw8300sw02) partially drains. Clothes spin out as dry as ever, but 2-4 cups of water are always left in the filter/pump. I've 1) emptied the filter 2) disconnected...
puzzled here because there is always some water left in machine this is normal .you are quite right when you say that when you take the drain hose out of stand pipe and lower it water comes out but that is because of gravity .
Jun 07, 2011 | Whirlpool Washing Machines
Is there a height requirement for the water inlet to a top loading washing machine? Is there a height requirement for the water outlet/drain to a top loading washing machine?
There is no requirement for the water inlet, but the drain hose does, one it comes out of the machine it needs to go up to roughly the height of the machine before it goes into the drain. Hope this helps
Mar 01, 2011 | Speed Queen Washing Machines
Wahing machine wont spin out with full load .will with small load
I would check to see if you have a kink in your drain hose. The timer allows the same amount of time to drain if it is a full load or a 1/2 load. If the drain hose is kinked it restricts the volume of water being drained leaving water in the tub when doing a full load.
Dec 30, 2009 | GE WBSR3140DW Top Load Washer
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Spin cycle slow unless hose lowered
you will have to take the hoses off the pump and clean the pump out its probably got sand in it
Apr 23, 2009 | Washing Machines
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Frigidaire FWS1339A Top Load Washer Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
