Question about Nokia N73 Cellular Phone
GPRS when i am trying to access gprs it shows"services:unable to perform operation" .i was able to use it in the earlier days but now it shows this problem.i am using a vodafone network (india).my phone shows this problem only to vodafone.i called the service provider .they said delete the settings and save again. i did but the result is the same.please help me.........
  • 304 Answers
Hi try to reset all the configurations in Phone Memory.
Before doing this backup your data.
Then you have to Reset the phone using *#7370#
Then it will asks for Phone Lock Code. The default code on Nokia handsets is 12345
After resetting the phone.. you have to define accespoints for gprs instead of defining accesspoints you can download settings from vodafone and save them and switch off the mobile and start the phone enjoy the GPRS in your mobile..
Hope This will works.....
bye...
Nandu
Posted on Feb 13, 2008
I want to set gprs on nokia supernova
Hi nothing to worry!
follow these steps to solve ur issue!
1. first u must activate gprs in both ur operator side and as well as ur side to access gprs in ur phone!
2. in operator side u must contact the operator and activate gprs( in most of the operator need msg based on the phone model to activate gprs in ur number)
3. it may take time based on ur operator
4. after activation u may receive the msg that gprs for ur num is activated
5. then move to ur side.
6. u may require the gprs settings to access the internet!
7. ask ur operator for gprs settings( settings are free and it may send you while u send msg to the particular number based on ur operator)
8. then u may got settings! try to save the settings as the default settings!
9. switch off and switch on ur phone.
10. then open ur phone browser! then start browsing!
plz make note that u may hav activate the corresponding gprs plan activated and also u may hav balance in ur account to access the service.
that's it! ur problem solved! Rate or comment me if u like!
Jul 23, 2011 | Nokia Cell Phones
My blackberry won't send or receive either texts or calls. But I can still do everything else like browse the web or send bbms..
This problem could be due to the lack of GPRS service. GPRS stands for General Packet Radio Service, and it's what allows your device to access data. The first thing you should do is perform a soft reset. If that doesn't work, perform a hard reset. After both resets, check your wireless antenna signal strength. The antenna should show GPRS. If you can still make phone calls and access the Web, then your GSM service is still available. Try sending yourself an email . Does it work? If it doesn't, call your BlackBerry provider. Sometimes, your service could be delayed due to a billing problem or to downtime on the network.
May 17, 2011 | RIM BlackBerry Pearl 8100
I have usiing samsung champ 3303 but is not supported airtel gprs and evrytime showing error "NETWORK ERROR" pls tel me best solution
You need to have the airtel gprs settings on your phone
>Account Name-GPRS
>Homepage- http://www.google.com
>User Name-Blank
>Password-Blank
>Proxy-Enable/Yes
>Proxy & Server Address-202.56.231.117
>Proxy & Server Port-8080
>Data Bearer-GPRS or Packet Data
>Access Point Name-Airtelgprs.com
>Authentication Type-Normal
>Use Preferred Access Point-No
>If you are unable to us application like opera mini,etc
-Then create another access point with same name & details& select it as the preferred access point.
>If you are unable to connect to internet from your mobile browser after entering the above settings simply turn proxy disable/no, save it & try again.
Mar 28, 2011 | Kodak Cameras
E-mail doesn't work, can text and use phone
This problem could be due to the lack of GPRS service. GPRS stands for General Packet Radio Service, and it's what allows your device to access data. The first thing you should do is perform a soft reset. If that doesn't work, perform a hard reset. After both resets, check your wireless antenna signal strength. The antenna should show GPRS. If you can still make phone calls and access the Web, then your GSM service is still available. Try sending yourself an email ?€" does it work? If it doesn't, call your BlackBerry provider. Sometimes, your service could be delayed due to a billing problem or to downtime on the network.
Mar 04, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
HOW TO ACTIVATE INTERNATE ON BSNL MOBILE?
SIR I HAVE GOT NOKIA 58OO.. AND ACTIVATED GPRS ALSO.... GOT SETTINGS FROM BSNL PEOPLE... BUT STILL MY PHONE IS NOT CONNECTING TO THE WEB... EVERY TIME IT SHOWS CONNECTION NOT AVAILABLE, AND UNABLE TO PERFORM OPERATION.....EARLIER IT WAS SHOWING PACKED DATA UNAVAILABLE.... IF I CONTACT BSNL PEOPLE THEY TELL GPRS ACTIVATED.... TELL SOME REASONS AND DISCONNECT... PL HELP ME
Jul 21, 2008 | Cell Phones
Unable to do gprs setting in kisen p83
boss normally in these cases
the mobile needs mannual update for ur gprs settings
please contact ur network operator
Feb 12, 2008 | Cell Phones
Gprs
Have you checked for the acess point setting. If you don't have already call your operator's customer care service for the settings. You must be able to use the GPRS services.
Feb 08, 2008 | Nokia N73 Cellular Phone
Unable to use gprs in Motorokr E6
hi, i am unable to use gprs in motorokr E6.i m using vodafone connection and GPRS is already activated on my cell form customer care.i tried a lot wid all the settings sent by customer care but it didn't work.plz tell me the possible settings/solution to use GPRS
Dec 19, 2007 | Motorola Mobility ROKR E6 Smartphone
Gprs
hi,
          ok as ur sayin that u have done the setting plz confrim the settings from SP, after that u can confirm that is there any spelling mistakes, than reset the cache setting and restore the handset. and try from " go to address option",, u will be able to access thes ervices,
Oct 14, 2007 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
134 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
