Question about Toshiba A45-S121 Notebook
Changing out memory
Does anybody know how to remove the back cover of a toshiba a45-s121 laptop? I am trying to change out the memory and can not figure out how to remove the back cover. i removed all of the screws and it still does not come off. Please respond ASAP.
Thank You,
Matt Sheridan
  • mattmrman Feb 11, 2008
    Wow that was easy thank you for the info it worked great!!!!!
  • Anonymous Nov 26, 2008
    trying to change the memory
How do i change the memory in my A215 laptop
Posted on Feb 24, 2009
  • 589 Answers
On that model, the memory is under the keyboard.
Here is a good tutorial on disassembly:
Although this tutorial is for hinge replacement, you will see the memory under the keyboard in step 17.
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
Posted on Feb 11, 2008
  • brian c
    brian c Feb 11, 2008
    I forgot to add, to change the memory, you can start at step #8
I formatted my toshiba satellite a45-s121 laptop then i downloaded the drivers and insalled them but now it won,t work on wireless it keeps saying a network cable is unplugged could u please tell me what...
have you checked if you have downloaded the correct driver....??because in most cases that happens if you have installed a wrong driver....hope if this works
Apr 25, 2011 | Toshiba Satellite A45-S121 Notebook
I can't find the place to add memory on a toshiba A45-S121.
You can view the user manual here. Click on 'Users Guide' and the the section on adding more memory begins on page 65. It looks like it's located under the keyboard, so you have to carefully pry the piece of just above the keyboard. There's screws underneath that which hold the keyboard in place. Remove these screws and and flip the keyboard onto its face. The memory modules are covered by a plastic sheet.
Hope this helps
Ray
Mar 06, 2011 | Toshiba A45-S121 Notebook
Should a toshiba a45 s121 mb post without memory installed?
No. The A45 series (and the near identical A40 series) have no base memory: at least one of the two RAM sockets underneath the keyboard needs to be populated for it to post.
Oct 16, 2010 | Toshiba A45-S121 Notebook
How do I replace the hard drive for my as45-s121 notebook?
open the cover at the back and take the HDD out.
remember that if you are not sure consult someone who knows.
May 09, 2010 | Toshiba A45-S121 Notebook
Changing the ram in my toshiba stellite a45 laptop
I don’t have a diagram for upgrading memory in this particular model, but it’s very easy. You can access both memory slots from the bottom of the laptop if you remove the memory cover. The cover is located in the middle, right beside the fans. All you have to do is remove 2 screws and remove the cover. I believe Satellite P15 memory is expandable to 2GB in both slots (Slot A + Slot B = 2GB) and you can use PC2100 DDR RAM, PC2700 memory should work too (it will run at PC2100 speed).
Check the laptop specifications before you buy new RAM module. I just discovered that different Satellite P15 models use different memory types. For example, according to Toshiba specifications Satellite P15-S409 uses PC2100 DDR memory, but Toshiba Satellite P15-S479 uses PC2700 DDR memory (I think it might be a typo, but not really sure).
Jul 31, 2009 | Toshiba A45-S121 Notebook
Need nic card driver to get online-(toshiba satellite a45-s121)
On the web, go to Toshiba.com and select your country. Look for support or downloads then choose your computer. You should get to a page that has all the latest downloads for your computer. You may want to download them all as they will be the latest, and install them.
Jun 07, 2009 | Toshiba A45-S121 Notebook
SHUTTING DOWN
I have the same problem and I tried everything and finally I realised it was one of the two ram modules installed. I took it out and it didnt turn off anymore.  But then I installed a 1gb ram module from my other laptop and the computer started shutting off whenever I connected the power adapter so I think it might be the wrong memory but taking the bad chip out solved the problem
Oct 30, 2007 | Toshiba A45-S121 Notebook
Toshiba A45-S121 Notebook Logo
311 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
