Convergence problem I hava a Pioneer rear projection TV that has a convergence probem, the main convergence is ok, the problem is with the outer edges convergence, its the blue outer edge convergance that can't be adjected, the rights edge can be adjected, the top and lower right also, but the upper left, lower left and the bottom middle all cannot be adjusted, I looked for open resistors and bad capacitors, I did not see any 392-110 in set, just where is this model is the convergence board located, there is a large heat sink with a small IC on the power supply board, but I could not read the numbers.
  • 3 more comments
  • Henry Brue Feb 11, 2008
    Model #is PRO-119
    Pioneer model #PRO-119
  • Henry Brue Feb 15, 2008
    I replaced both convergance IC's,and the unit works ok
    I replaced both convergance IC's and the unit works OK
    ThanKU
    I replaced both convergance IC's and the unit works OK.
    ThanKU
  • 552 Answers
Https://www.manualsparadise.com
In order to help you more, it may be a good idea to go to the above web address and see if there is a repair manual for your model.
Posted on Feb 11, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 12, 2008
     Your convergence system may have stopped functioning properly. Repairing it usually entails replacing the OP ICs, on the convergence board.That board is to the left side, vertically mounted, as you look at the inside of the back of the unit, back plate removed
    The conv board is a 2 level board, with one board on top of another one.
    The ICs are in between the 2 boards. They are mounted to the bottom board, and there is alot metal plating taking up space , making soldering on it very challenging.
    the E3 and E2 connectors, as well as two IC connections may have cracked solder joints. Using a fine point heat controlled iron, reflow all of these joints.
    Check for other questionable solder joints.
    These are just suggestions.
    UNPLUG POWER FIRST! It is not worth getting hurt just to save a few dollars.
    President:
  • 3,130 Answers
What model number of Pioneer TV set do you have? There should be a large heat sink or something metal with cooling fins on it where the IC's might be mounted away from you so you will need to look at the other side of the heat sink. Replace those IC's and you will be able or should be able to adjust the set providing you have not tweaked it too much before repairing the problem. Good luck
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Feb 11, 2008
    OK Great! I happen to have a copy of that service manual if you would like a copy. I will need an e-mail address where to send it to.
  • Larry  Dillon
    Larry Dillon Feb 13, 2008
    So, do you still need the service manual for this set? The boards ARE NOT multilevel by the way. They are only 1 type of board for thgis TV set.
  • Larry  Dillon
    Larry Dillon Feb 15, 2008
    Your Welcome. I can still send you the factory service manual if you like.
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
The outer edges of my screen are showing double images ie I get blue and red images
Adjust the cross hairs on your TV. See menu setting for convergence. If this will not cure the problem..you have a bad convergence board!
Jan 07, 2010 | Zenith R57W46 57" Rear Projection...
When we turn on our TV, the picture is almost "bowed in" (rounded inward, and the outer edges are fuzzy) and it takes quite some time for it to straighten out. HELP!
Convergence it dying or will be dead soon.Know how to solder right?Buy a convergence kit replaced what in that kit.Tries Tv Repair World.com Or Tv Repair Kits.
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
JVC AV56-WP74 Convergence problem
Hello saduchan,
I think that your ICs are ok, What you need to perform is what is called dynamic convergence, This involves using the internal convergence controls to align the outer edges of the screen. I am assuming that the center of the screen is ok? it's just the edges which are misaligned, right? Now for the bad news, this task is not easy in fact the job takes a pro about 6 to 12 hours to do it right. I think you should have a qualified TV technician attempt the static convergence setup followed by the dynamic convergence setup.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
yes better.  you need schmatic. servicemanuals.net.
Dec 13, 2008 | Toshiba 42H81 42" Rear Projection...
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Convergence problem?
If it's OK when first turned on, I would suspect either bad solder connections on the convergence or power supply board, or capicators on either board heating up and breaking down. Pioneer parts are expensive, so I would look for a shop that can do component level repair. You may save about $100 or so.
Jan 18, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Convergence IC's
It does not sound like a convergence problem as you stated that all the lines match up and are ok??? You have space at the top and the bottom, as well as on both sides? Well my friend it sounds like you have a power regulator problem with the main power supply, because it sounds like the voltage is low and causeing the set to have a smaller then normal picture. Check the Main B+ first. I dont have a schematic but if you need, I know lots pof authorized pioneer peeps, and can getbwhat voltage and what part is most likly bad. We hardly repaired the boards as they(pioneer ) did not have most of the descrete parts and mostly had the boards themselfs to replace. You could also take out the B+ regulator board and have it rebuilt at PTS. They have a web addy of http://www.ptscorp.com Look them up and get their tele # and call them to see about the replacement cost. If they can't help go here Main support number800-421-1606. Good Luck
Jul 27, 2006 | Pioneer PRO-710HD 64" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
