Question about Canon PC-940 Black and White Copier
Canon PC940 Problem
My Canon PC940 copier prints all black copies. It is lightly used and about 3 years old. I changed the toner cartridge and the problem persists. Cannon support suggests that condensation would cause this and I should leave the machine open for 2-3 hours. We did so and the problem remains the same. Has anyone experienced this and found a solution? Any suggestions or help would be sincerely appreciated.
  • Anonymous Apr 16, 2009
    eo lights up copier automatically shuts off when turned on
  • GLPF Apr 16, 2009
    Prints all black or almost all black copies, no matter the contrast adjustment. Also makes a crackling sound as it runs the paper through.
    Replaced toner cartridge and still has problem. Old cartridge has toner sifting out 1 end when I move it. New toner cartridge so far does not have toner sifting out and is making copies w/ large black lines/patches, it is still making the crackling sound.
    Problem Solver:
  • 14 Answers
You could have a broken exposure lamp. Does the scan bar light up when you make a copy? If not that is the problem. You might also ck the contacts on the machine where they touch the toner cartridge. The toner cartridge opens a shutter to the drum when you slid it into the machine and that may be broken.
Posted on Feb 13, 2008
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
Toner spots on copies. same location each copy
if the spots stay in the same location, its 100% something on the glass or on the platen cover.
Feb 14, 2015 | Canon Pc940 Alog Copier 13cpm 0008a040
Printer is printing to light for my needs...has a new toner
Verify the toner cartridge.Open the glass platen cover and make a copy,not used an original,if the cpy is a full black papier thr toner density is OK,Clean the polygon unit glass.Enter in program and perform a test page.
Apr 04, 2013 | Canon MF6530 Black and White Copier
How do you change the toner in a Canon PC940 copier?
You have to replace the whole toner/drum unit cartridge. There is handle on the left side. Release this and then the whole reader section of the copier will move left. Raise the right side cover asnd below this is the drum cartridge. Gently lift out and replace it with a new one.
Jun 03, 2011 | Canon PC-940 Black and White Copier
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
I want a service manual for my canon pc940 copier
Just installed a new cartridge. Made one copy. worked great.
Went to make a copy today. All Black. Thought about it. Tried again and noticed lamp was not lighting. Before you say DUH! is the lamp out or is their extenuating circumstances preventing the lamp from lighting during a copy. The table top moves and everything else seems to work accordingly.
Sep 27, 2010 | Canon PC-940 Black and White Copier
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Toner is jam and will not come out.
Generally with a PC940 you must rotate the old toner cartridge clockwise to get it out.When you put in the new one, after pulling the tape off turn it counterclockwise to get it to work.Good Luck
Mar 17, 2009 | Canon PC-940 Black and White Copier
Pc940 faded centre
Have you replaced the drum cartridge yet? Or did you and this what you are getting. If the old drum was working ok, but dark. You may have a defective drum unit.
Feb 06, 2009 | Canon PC-940 Black and White Copier
Canon PC940
PUT THE OLD CARTRIDGE BACK IN AND SEE WHAT IT LOOKS LIKE. IF ALL BLANK SOME WHAT LIGHTER, YOU MAY HAVE A BAD CARTRIDGE (NEW ONE) WIPER NOT CLEANING DRUM OFF. CHECK TO SEE IF EXPOSURE LAMP IS COMING ON....IF NOT BAD LAMP...
Nov 30, 2007 | Office Equipment & Supplies
Canon PC-940 Black and White Copier Logo
529 people viewed this question
old marine
old marine
