Question about Kitchen Ranges
Oven burnout after a power outage, my oven stopped working,but the stove top still works. all the digital settings are gone including the clock.
  • 1 more comment
  • Anonymous Feb 25, 2008
    bottom oven not working
  • Anonymous Jan 24, 2009
    I have the same problem with my digital read out but if i turn on of the eyes on and set the clock then the oven will work. but once I turn the eye off the digital read out goes black
  • robert samples May 11, 2010
    whats the brand and model number
  • 5,911 Answers
The oven is controlled by an Electronic Range Control (ERC). This is the clock assembly on the range. The surface elements are powered by infinite switches and do not go through the ERC. That explains why the clock assembly is dead, your oven does not work, but your surface elements do. You need to replace the ERC. If you can provide me with a model number (located near the oven door or bottom drawer opening on most ranges, on the back of the console on some) I can determine what type of ERC you need and how much it might cost you. Post back with comments and let me know if I can be of further assistance. I hope this helps you.
Posted on Feb 11, 2008
Same problem happened to me last week. Kenmore electric stove only 3 years old. Repairman replaced electronic board ($400 on warranty, thank god), saying it is a continual problem with these stoves and is likely due to to power surges. Said it is an engineering defect. So my question to anyone - how do we prevent this from happening again? Use a Power bar like i do on my computer?
Mark from Canada
Posted on Mar 05, 2008
  • 552 Answers
This may be due to one half of your circuit breaker being tripped or if you have cartridge or screw in fuses in your electric panel, then you need to be sure you have both halves of the 240v to your range.
There may also be a fuse in the range up at the controls that blew.
You will have to take covers off the back to see.
Being a digital readout, power surges can cause damage to sensitive electronics.
Sometimes you can see burned circuit boards etc. by examining closely.
Frigidaire stove
Power outage could have shorted out the control panel. Call the power company and put in a claim with your insurance company. Tis happened to me & I was able to reset the oven, even with a glowing bright & dim panel. Thought everything was ok but the upper oven doesn't stay on & the oven probe doesn't work, but it's too late for me to file a claim.
Sep 05, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Stove top works but dispplay and oven do not. had power outage which caused this
Replace the clock .takes it out almost every time.most newer ovens the clock runs everything but your top burners .call repair clinic.com and order clock.(main control board.) Number is 1-866-822-0890 or 1-800-269-2609
Nov 08, 2011 | Ovens
Kitchenaid superba electric oven (includes convection feature) and the entire digital panel suddenly stopped working after 6 years of perfect service. The stove top burners (acrylic top) appear to be...
It sounds as if the electronic clock/timer has failed and needs replacing. If you don't use the timer and don't need the clock it can be bypassed so that the oven will still work. A repair person should be able to do this fairly easily.
Feb 13, 2011 | KitchenAid Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Power outage - no manual so dont' know how to get oven to work
Hold down first 2 buttons with left hand and then press last button.(still holding down the first 2) This will bring up numbers 12:00 which means you can set the clock and also the oven will work.
Aug 25, 2009 | Stoves Kitchen Ranges
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Inglis Royal electronic stove. Wehad a power outage. How do you reset the clock
To set the time. The top strip on the upright part of the stove , where the clock is, flips up. The directions are under it.
Jul 09, 2008 | Kitchen Ranges
Oven burnout
replace the oven control
Apr 25, 2008 | Kitchen Ranges
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
429 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
