Question about HP 4250 Monochrome LaserJet Printer
INK ON SIDE OF PAPER
The printer is printing fine but with light black ink on each sides of the paper...sometimes you can make out small words in it....happens about %70 of the printouts. Not sure what the problem is. Could it be the wheels that feed the paper have ink on them?
    President:
  • 4,402 Answers
I would replace the toner cartridge first.
Posted on Feb 11, 2008
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Why would paper be jamming or getting stuck on right side with black ink every time?
The rollers that advance the paper could have been messed up by the key, therefore crinkling paper and not advancing in proper timing with the ink. It also could have busted of the plastic gears in modern day printers.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Apr 24, 2012 | Epson Workforce 610 All-In-One InkJet...
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
My printer prints pictures fine but when i print words it dont print black ink just colors why
Black printer ink in Canon Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Nov 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Black wont print
THE BLACK INK CART. either dried or end , make a test , take out the cartridge and get a piece of paper towel and pass it gently
where the ink is .hope this helpful AJ
May 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Mac leopard -epson tx400 - printer grabs paper - printer very noisy, desk shakes with vibration - now the print on paper is faded help!!
Hello, sorry to hear you are having trouble,
So, are we to understand that your printer did not shake with vibrations and make a lot of noise before ?
Most of these ink jet printers have heads that travel very quickly and abruptly from side to side causing shaking and vibrations, especially if it is on a light weight desk or table, sometimes to the point of almost throwing itself right off the table. This is a normal state for the printer to be in.
Then, you say the paper is printed on, it goes right through to the end, no paper jam, but the colors are faded...
How often do you print on this printer ? Sometimes, the Epson print head dry up and only small amounts of ink get through even though the system indicates that the ink is full...
You can certainly perform a head cleaning operation, I recommend doing it several (3) times to be sure, unfortunately, it's a terrible wast of ink.
Finally, have you replace the ink cartridges? If you get a faded output with new cartridges, you may have inadvertently activated the ink saving or draft mode, go through you page set-up or printer option thoroughly.
I'm pretty sure something here will get you out of this mess.
Mar 27, 2009 | Apple iMac 17" Desktop
Won't print black ink
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Unplug the Power Supply from the printer.......
Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button..........
Now the Printer will ask for the Date Time and Country Language.........
Set everything up......
Now try to Print i am sure it should work..........
Good Luck............
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Problem with printing page
Replug in the Power Supply......
Try to Print it will work fine..........
Jan 05, 2009 | Lexmark X2500 All-In-One Printer
Black ink splattering the sides of the paper
remove ink cartridge wipe off print head area with rubbing alcohol
applied to a microfiber cloth
Jan 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
HP 4250 Monochrome LaserJet Printer Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
