Question about Polaroid DRM-2001G DVD Recorder/HDD Recorder
Polaroid drm-2001g repair
When I purchased this item I absolutely hated it but once I got past the poor documentation and the lame tech support from Polaroid, I actually began to like it. I seem to have a problem with the dvd burner/player in the unit. It has been giving interment problem for some time now and it seems to have died. The hard drive, recording to the hard drive and play back from the hard drive seem to work fine, but I can not burn programing off to DVD's. Is the DVD unit in the machine replaceable, where can I get one, and it it a simple repair. Or can someone refer me to someone who can make this repair fir me. I don't mind replacing the entire unit but I need to get the recorded data off the hard drive,
  • 1 more comment
  • olopez2 Feb 21, 2008
    Hi everyone, I am having the same problem, HDD burn to DVD is not working !!! What is the problem ?
  • hplakeside Jul 09, 2008
    I have the same unit, the Poloroid DRM2001G and I cannot play or burn DVDs. Also, when the machine is cut on it has a loud whine which stops after a few seconds. Everything else works fine.
  • Anonymous Jan 31, 2009
    Can record prgrams to hard drive. dvd will not goto finalize disk, information is on disk it just will not finalize.
mastersaintx
  • 928 Answers
SOURCE: looking for owners manual to downlad for polaroid
Click on the link below then click on User manual
http://polaroid.com/service/product.jsp?PRODUCT%3C%3Eprd_id=845524441764403&FOLDER%3C%3Efolder_id=282574488338773&bmUID=1227733689618&bmLocale=en_US
Posted on Nov 26, 2008
  • 226 Answers
SOURCE: DRM-2001G weak remote
The range problem with the remote can be fixed by replacing the LED in the remote with a Radio Shack 276-143. The LED is a lot stronger and now the remote works a lot better.
You may also find that the 'receiver' inside the cabinet is pointed at an angle instead of directly towards the 'window'. You can trim the rubber(?) to allow it to point correctly.
Posted on Apr 29, 2009
  • 226 Answers
SOURCE: replacement remote needed for Polaroid DVDR DRM-2001G
There is a group on the Web that messes around with what they call "JP1 remotes". All remotes of this type have a 6-pin connector that can be accessed/connected by a PC using a special cable. A parallel port, USB, and maybe serial RS-232C connection work.
Go here: http://www.remotecentral.com/cgi-bin/mboard/rc-one4all/thread.cgi?5101,4
Read the article. I would suggest reading from page 1. You can program a JP1 remote to do all the functions specified in the graphic on that web page.
tom
Posted on May 11, 2009
  • 226 Answers
SOURCE: vertical flipping
I bet you put it into PAL mode, the European standard. I believe that you can reset to factory default using the menu and it should be okay. If you cannot read and navigate the menu tree, then I think that if you hold the power button on after you start up, it will reset itself. I have not checked the doc to make sure of the last.
You can also get display problems if you pick the Y/R/G component setting in the menu. It is designed for connecting to a high definition using 3 different cables, one for each color. It only supplies vertical on one of those cables, and the TV just doesn't know what to do without the vertical blank signal from 'somewhere'.
Again, a menu setting.
tom
SOURCE: default password to unlock hard drive video on
Default password for DRM-2001g is: 3308
Posted on Feb 07, 2010
I have the polaroid dra-01601a dvd/hdd audio
First of all with all do respect I do not have the polaroid drm 2001G. I have as I exprest in my letter to you the polaroid dra 01601A. The problem i had was an audio problem and i simply rechecked all my connections and found that I needed and extra set for HDMI plugs on my TV.
Jan 03, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
No audio on polaroid DRM-2001G
just unplug the power cable for few seconds
Oct 21, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Replacement remote needed for Polaroid DVDR DRM-2001G
You need to change the IR LED in the remote. I swapped in a new one from an old remote and it works great, no pointing and walking up to the unit with the remote.
Apr 08, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Apr 06, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
DVR making bad DVDs
Three suggestions:
1) take it apart and clean the laser and the spindle 'hub' that the DVD rests on
OR
2) get a 'cleaner' disk that will 'whisk' any dust from the laser diode.
OR as a final suggestion
3) replace the DVD recorder with another. Plain old EIDE parallel interface units fit fine.
This is a very friendly machine in that it will accept PC compatible hard disks and DVDR drives.
tom
Feb 04, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid Will NOT edit out Commercials!
You need to post edit the recording;
First unprotect then do a split before the commercial
than split after, then recombine the parts without the ad.
Cumbersome, but it works
Feb 12, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid DRM-2001G DVD Recorder/HDD Recorder Logo
424 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
