Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Dishwasher will not go thru wash cycles
By dwanna4 on Feb 11, 2008
I have full power going to dishwasher.  When I turn it on it fills with water but it wont run thru the cycles even though I can hear the timer going through its cycles. Once the timer has finished it will not drain. Any suggestions will be greatly appreciated
Hotpoint HDA2000 has worked before. It now fills with water but nothing else happens. And I don't know what to do to drain the water.
I have a kenmore built-in dishwasher. It fills with water and then it stops. It will not wash. It then will go thru the other cycles and then will say its clean. When I open the door it is still full of water.
Comments:
Feb 18, 2008
- The Kenmore Model no is 665.1586580.
Feb 21, 2008
- After it fills no!
Feb 25, 2008
- After the kenmore fills it does nothing. There are no sounds. Forget about all other washers. Im just asking about the kenmore.
Clarification Request
Posted by tech17 on Feb 11, 2008
do you have 1,2,3, dishwashers i don't mind helping but need to know what were dealing with and whats the model number of the first one
Same Problem
Mar 02, 2008
-   dish washer full of water will not empty water-   Guest
Solution #1
posted on Jul 09, 2009
Not Rated)
mike_fuson
Rank: Wiz
Rating: 83%, 259 votes
if the water is not draining at all in any of the cycle it is probably the discharged line at the bottom of the pump has become blocked. there is an access panel at the bottom of the dishwasher which will allow you access the line. take the line off of the fitting , use a set of vise grips to remove the fitting from the base of the pump.You will probably find corn or rice lodged in the diaphragm within the fitting, remove debris and reinsert the fitting and hose. Hopefully this is helpful to you.
Was this helpful?
Yes
No
Solution #2
posted on Feb 18, 2008
Not Rated)
tech17
Rank: Guru
Rating: 88%, 1513 votes
doy you hear any sound from either in the wash cycle
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
water leaking out of front top air vent after drying cycle when you open door
Answer
i have a whirlpool dishwasher my glasses and silverware come out cloudy.how do i prevent this or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
