Question about Frigidaire GLRS237ZA Side by Side Refrigerator
Fridgedaire glrs237zcb3 The fridge has completely stopped working. There is a large humming noise coming from the back of the fridge that comes on every minute or so that sounds like the motor is trying to start but can't. Is it the motor or compressor?
    President:
  • 1,314 Answers
About the only thing you can do here is take the back cover off the unit see if the cooling fan for the compressor is running if it is and there is an Indian on the compressor then the compressor should be replaced if the fan isn't running then clear the fan once its running then turn the unit off for 30 Min's and try again
Posted on Feb 11, 2008
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
GSs 22 wg refrigerator humming noise from freezer. Tech came and replaced defroster heater element but humming remains. What is the likely cause of this? It comes and goes but is mostly on. Fridge...
most likely it's coming from the evap fan motor or the ice maker,try shutting the ice maker off first to see if that's the problem,if not then i'd go with the fan motor,you can try opening the freezer door,this usually turns the fan on,then push in the door switch button and see if the fan stops blowing and if the noise stops too.hope this helps you out.
Jun 12, 2011 | GE Refrigerators
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
GE - SIDE BY SIDE MODEL TFX25JR - Continous HUM
Probably the condenser fan motor is going out they will often make noise for a long time before anyone notices. Get it looked at soon. overheating the compressor on that old of a fridge could spell trouble.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
A side by side GE refrigerator with a loud hum
Hello Kchoffman73,
It sems we developed the same problem.
The hum seems to be coming from the bottom rear of the
fridge.
we have a GE side-by-side model TFX25JR.
The fridge is about 12 years old.
Whats the status of your fridge ? Did it ever stop
humming ? Did you replace or repair it ?
Does it still work ?
Thanks
Sep 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
158 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
