Hi
KIndly check antenna/cable connections. Are they properly secured to the TV’s ANT75ω plug? If they are then :
• Check the
TUNER MODE control for the correct tuner setting.
• Try running the Auto Program feature to find all available channels.
• Press the
AV button on the remote to make sure the correct signal source is selected.
• If using an accessory device, be sure that it is functioning properly.
• If in PC Mode, a video signal
MUST BE present or the TV will turn off.
If this does not work then
reset to the original factory settings by performing the following steps:
Press the MENU button on the remote control to see the onscreen menu.
Press the CURSOR DOWN button to highlight the INSTALL menu, then press CURSOR RIGHT to enter.
Press the CURSOR DOWN button repeatedly to highlight the FACTORY RESET control, then press CURSOR RIGHT to enter.
Press CURSOR DOWN to select “YES” to reset the original factory settings.
Press the MENU button repeatedly to clear the menu from the screen.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
