Question about HP PSC 750 All-In-One InkJet Printer
Hp psc 750 says out of paper
I've cleaned rollers, turned off and on, checked for correct paper weight. This is a fairly new printer, barely used. The paper won't feed into the rollers. Can I fix this?
  • jcp139 Jan 08, 2009
    The paper tray wont lift to let the rollers grab the top piece. It then says 'out of paper'
    President:
  • 4,402 Answers
You did everything possible only thin you haven't don't is unplug it, which i dont think will help, time to have it serviced. or call hp.
Posted on Feb 11, 2008
Having a problem with prtinter it's not feeding right keep feeding from right side...tried putting one paperat a time but still not feeding right....PLEASE HELP...
Using high cotton paper causes cotton dust build up making it hard for the rubber rollers to grab the paper. Check inside for paper dust build up. If so, clean rollers with a window cleaner.
Another problem is saving too much money on paper. There are some very thin light weight papers which the printer rollers have a hard time gripping. Most printers do well with 22 lb paper. Otherwise you may need to put a piece of scotch tape under the roller so the machine can grab the thinner paper.
Also check your side paper alignment guide in the tray. As well as making sure your paper is sitting all the way back/down in the tray.
Apr 13, 2011 | HP PSC 1610 All-In-One InkJet Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
The paper keeps on jamming now and/or coming out the back end of printer. I'm using the correct HP paper? What can I do?
Remove the back cover from back of printer. (by holding notch and pressing to the right side then pulling)
The part removed is responsible for directing paper to the top. Clean rollers by as applying a lighly damped lint free cloth and check if every roller is turning by finger.
Now, put back the cover by inserting the right side first and push.
Good luck
Nov 29, 2010 | HP PSC 1610v All-in-One Printer
My HP printer is not feeding paper.
Here is the solution for your problem just go through the steps given below and you can fix it yourself.
1. Check to make sure your printer has paper in its paper tray. If your printer has paper, check to make sure that the tray is not overloaded. If you suspect your paper tray is overloaded, remove some paper from the tray and attempt to print again.
2. Use the same type of paper when stocking the tray with paper; do not mix different types of paper into a single stack. Mixing different brands and weights of paper in a single stack makes your printer more prone to paper feed problems. If you find that one particular type of paper causes consistent feed problems, switching to a different type or weight of paper may solve the problem.
3. Check to make sure the paper in the tray is whole. Torn and creased paper will cause problems with the printer.
4. Open your printer's rear access cover and inspect the paper feed rollers. Dusty or dirty rollers cannot grip the paper; clean them with a soft, damp cloth and water.
5. Count your printer's rollers. HP printers have six paper feed rollers; if your printer is missing rollers the paper will not feed correctly. Contact HP to replace the rollers and repair your printer.
Thanks.
Oct 06, 2010 | Computers & Internet
750 all in one printer
Can you see any paper in the rollers? I can only think careful use of twesers AS you probably found out printers appear to be Snapped together ie no easy screws to undo! Have you tried the HP help line? Good luck!
Jun 12, 2008 | HP PSC 750 All-In-One InkJet Printer
Out of paper
Paper Pickup roler need to replaced
Jan 16, 2008 | HP PSC 750 All-In-One InkJet Printer
Printer
When you clean the rollers, use alcohol. The clicking noise may be the plastic drive gears have a broken tooth.
Feb 04, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
52 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
