Question about Avaya IP Office 4620 Telephone 700212186
Loosing time on the ip phone
What could be thr reason my ip phone is loosing or gaining time
    Problem Solver:
  • 5 Answers
The phone should not lose or gain time unless the time on the PBX that it is connected to is being changed. Sometimes the IP phone may lose connectivity to the PBX and the time may stall but when the connectivity is reestablished the time should update.
Posted on Feb 11, 2008
How to access Cisco Unified Communications Manager Administration ?
from what I have researched on the web you need to download the Cisco unified Communications Manager software on to the P.C you wish to use to access the server via the web browser. it states you open the software via a web browser. The reason being the Voip server has no software on it.
http://www.cisco.com/web/developer/cucm/content/download.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/CUCM_BK_A09578D7_00_admin-guide-cucm-imp_1151/CUCM_BK_A09578D7_00_admin-guide-for-cucm-1105_chapter_01.html
Apr 20, 2016 | Cisco 7940 IP Phone
Bizhub c550 loosing network access
does the copier have a static IP address or is dhcp meaning ever time the network is turned on the copier get a new/different ip address. Copiers love static so recommend your it person assign one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 11, 2014 | Konica Minolta Bizhub C550
Where does the avaya 9620 receive it's time from?
What system is the phone on? If IP office, you can designate a time server, or it could use the voicemail pro PC.
Jul 18, 2012 | Avaya 9620 IP Phone
What is the default username & password for the SPA921?
According to the manual (http://tig.csail.mit.edu/manuals/spa941.pdf) there is no username/password when you first use it. Perform a factory reset to gain access to this.
Mar 28, 2011 | Linksys SPA921 IP Phone
My blackberry fell on the floor a few times and now the scroll pad isn't scrolling, i can click but it move across or up and down, help me, what can i do?
take ther battery out of your phone. Take toothbrush and a can of air and see id yu can get it tomwork. if that diesn't help shake the phone to see if yout anything loose on the inside. you may have knock the thr navgiation pad off track. The pad is like thr one son a pc. if you haven't taken one apart before don't now because you could lose the pieceson the inside or carack thr pad. call bb to dee if they have a warranty ceneter you can send thr phone to. Their isn't much motr outside of cleaning thr pads .It usually is a seal pad. Sorry I couldn't help more
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Mar 23, 2011 | RIM BlackBerry Curve 8520 Smartphone
How do i manually configure and ip address for the mitel 5224 ip phone?
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Feb 10, 2011 | Mitel 5224 IP Phone
Hi, I need to set the IP configuration on my MITEL 5212 IP Phone manually, but I do not know how to do it. I guess that there is a sequence of key to press, any help will be appreciated.
Press and hold the up arrow key while booting the phone. Configure telephone - YES, Network Parameters - yes, then NO until you see Change. Set the appropriate information, IP address, default gateway, ICP IP address, TFTP server address, etc.
You should be warned that this gains nothing except making another device on the network that requires deliberate management.
- Mark
Feb 02, 2011 | Mitel 5212 IP Phone
Describe your avaya 5610sw ip enter commandproblem hello. I cannot logon to my telephone for some reason. I have restarted the phone many times. The screen says "phone =***.***.x.xx" next line says...
Enter the IP information. if you leave the IP at all zeros, it will grab DHCP (if available).
Press the pound (#) sign to continue.
Callserv IP is the IP of teh phone system.
press pound to continue.
Jul 03, 2010 | Avaya 5610 IP Phone
Hi it is my first time using a IP Phone SPA901, The red light is blicking, do you know why?
the reason the red light is blinking is because you have a voicemail
Oct 06, 2009 | Linksys SPA901 IP Phone
Chaging the time on the 5212 IP system
The time and date are a system wide change. If you have access to you ICP, after you gain access the first screen to appear will have three option choose the "Group Administration Tool" click on change date and time and the rest is self explanatory.
Nov 13, 2008 | Mitel 5212 IP Phone
Avaya IP Office 4620 Telephone 700212186 Logo
190 people viewed this question
Top Avaya Computers & Internet Experts
David Payne
David Payne
PhantomLib
Level 1 Expert
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
