Question about Macally iPocket MAIPOCKET
Ipocket 512M my ipocket 512M is detected by the computer, but cannot start when off the computer. pliz help me now
  • Anonymous May 01, 2008
    My computer recongnizes rhe Ipocket. But I can not put any music on d
    the Ipocket. Nor can I start up the Ipocket. Either connected to the computer or disconnected from it?
    What can I do ??
Push the start button it will be in sleep mode now keep pushing the m button and if its oke it works ^^
Posted on Sep 14, 2008
My pendrive cannot open and also cannot format what to do pliz tell me
would help if you can post details on what happens when you try to open the pen drive or when you try to format it, like is it actually detected by your system, or is there any type of error?
as a suggestion, try to test it on different USB ports on your computer. If it is actually detected, which means, there is a drive letter assigned to it, open the DOS/Command prompt. If you are using Windows OS, type format X:\ and press the Enter key. Be sure to substitute X with the correct drive letter assigned to the pendriive. Hope this helps.
Aug 25, 2010 | Computers & Internet
I have a inovix ipocket and need headphones for it. Can't find it anywhere because the headphone jack is smaller than the standard headphones.
go to a phone shop and buy a 2.5mm headphone to 3.5mm adapter that will work and you can use normal headphones
May 20, 2010 | Audio Players & Recorders
I have an ASUS P5V800 motherboard. I have been having problems with the computer hanging at random times during start up. Sometimes it hangs before the mem test, sometimes during hard drive detect,...
Have you tried cleaning the connections and as well as the motherboard? Based on my experience, dust, especially moist dust that has build up inside the CPU tower can cause malfunctions. What i usually do is i dismantle the CPU tower and clean the components inside with soft-brissled paint brush like heat sink and fan, motherboard, graphics card, etc. When in come to the RAM i clean the pins with pencil eraser like shown in the image below.
and re-assembling them again. hope this helps
Sep 26, 2009 | ASUS P5V800-MX Motherboard
Replaced 512M DDR with 2G DDR2, only sees 512M
This often occurs as a result of fast/quickpost settings in your bios.
You will need to shut down your system, boot it, then quickly read the black and white screen.
Then press whatever button your system displays as the setup or bios button, generally Esc, Del, F1 or F2 but can be anything.
Once in your BIOS just browse around until you find the setting marked Quickpost, Fastpost, Quiet Post, etc.
When you find the setting, Disable it, save the settings and reboot. Once you're done rebooting, check the system properties. This should do the trick, then repeat the steps to re-enable the quick mode, and reboot again. It only needs to be disable for one boot sequence to allow the computer to find and add the new hardware to it's BIOS setup.
Hope this helps FixYa,
May 05, 2009 | Computers & Internet
Huhu.. hellp me to format my n70 mmc.. help pliz!!!!!!!!!!!!!!
try format it on your pc and your phone. if still the problem persist then you should buy a new one. im sorry!
thank you for using fixya
Nov 24, 2008 | Nokia N70 Cellular Phone
RAM Memory upgrade
K8V SE Deluxe DDR400 Memory Qualified Vender List
The following table lists the memory modules that have been tested
and qualified for use with this motherboard.
Size Module Vendor Model Chip Brand
256M Micron MT8VDDT3264AG-40BC4 Micron SS MT46V32M8TG-5BC
512M Micron MT16VDDT6464AG-40BC4 Micron DS MT46V32M8TG-5BC
128M Infineon HYS64D16301GU-5-B Infineon SS HYB25D256160BT-5B
256M Infineon HYS64D32300GU-5-B Infineon SS HY25D256160BT-5B
512M Infineon HYS64D32300GU-5-B Infineon DS HY25D256800BT-5B
256M Infineon HYS64D3230HU-5-C Infineon SS HYB25D256800CE-5
512M Infineon HYS64D6320HU-5-C Infineon DS HYB25D256800CE-5
512M Samsung M368L6432ETM-CCC Samsung DS K4H560838E-TCCC
256M ATP AG32L64T8SQC4S Samsung SS K4H560838D-TCC4
256M Brain Power B6U808-256M-SAM-400 Samsung SS K4H560838D-TCC4
512M Brain Power B6U808-512M-SAM-400 Samsung DS K4H560838D-TCC4
512M Apacer 77.10736.464 Samsung DS K4H560838D-TCC4
256M ADATA MDOSS6F3G31YK1EZZ Samsung SS K4H560838D-TCC4
256M Hynix HYMD232646B8J-D43 AA Hynix SS HY5DU56822BT-D43
256M Kingston KVR400X64C3A/256 Hynix SS HY5DV56822BT-D43
512M Kingston KVR400X64C3A/512 Hynix DS HY5DV56822BT-D43
512M Winbond W9451GCDB-5 Winbond DS W942508CH-5
256M Kingston KVR400X64C25/256 Winbond SS W942508BH-5
256M ADATA MDOWBFF3G31JB1EAE Winbond SS W942508BH-5
512M TwinMOS M2G9J16AGATT9F081AA4T TwinMOS DS TMD7608F8E50D
ive found the best prices at and they ship it right to your door. make sure the tiger ppl have the exact match and dont replace your order with more expensive replacements as some of these substitutions require voltages that your motherboard CAN NOT produce and will not work.. you also want to make sure to buy low density ram, it performs better, is a few bucks more than high density, but worth EVERY penny. E-bay is notorious for selling cheap high density ram on thier site.
If you stick to the list above, you shouldnt have any issues.
This should fixya up! please rate...
Oct 28, 2008 | Computers & Internet
IPocket problem
Check the mp3 player's settings and look for intro-play option (like play only 5 seconds from the start).
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 07, 2008 | Audio Players & Recorders
To get ride of Canon Pixma MP160 Service error 5010.........!!!
Pliz help me out and fix the service error 5010 which i get as soon as i turn on my printer and due to which the alarm light starts blinking, i'm helpless coz either my printer or Scanner isn't working, so pliz stretch out your helping hand in order to let me get ride of this.
Feb 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Replacement cable for Ipocket
This is not Macally product.
Dec 31, 2007 | Macally iPocket MAIPOCKET
Computers & Internet Logo
77 people viewed this question
Top Macally Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
