Question about Mitsubishi CS-35505 35" TV
1993 tube 37" mitsubishi
Has a horizontal line in the middle, you can hear the sound with no problem but no picture, it appears that the line in the middle of the tv is part of the picture.
  • 2,336 Answers
It looks like the vertical amplifier IC401 is defective. If you have soldering/desoldering skills you can change this part yourself. Also you may have to change C471 (.01UF 50V).
Good Luck.
Posted on Feb 11, 2008
Horizontal line in toshiba TVs
its the horizontal output IC
Feb 14, 2010 | Toshiba 28N33 28" TV
Single horizontal line in middle of screen
Yeah, thats the tube, buy a new one. It's 15 yo anyway, let it go ;) Best of luck!!
Aug 31, 2009 | Televison & Video
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
Jul 04, 2009 | Akai Televison & Video
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Horizontal line in the middle of the television
Look maybe if you resolder vertical IC you will repair this set ,Or replaced it. But a lot times just need be re solder. Thank you
Aug 19, 2008 | Televison & Video
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Black screen with green smiley face
If your tv has a picture tube,your problem is in it. If you have only one line now,the vertical circuit is not working. You could have jarred something loose around the picture tube.Maybe a yoke lead ???
Jan 13, 2007 | Mitsubishi VS-60607 TV
Televison & Video Logo
202 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
