Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic TV Repair
I was watching my Panasonic 50" widescreen HDTV when the screen went black and had verticle strip of color in the middle. The volume is fine, but the screen is now totally black when I turn it on. Can I fix this myself?
    President:
  • 3,130 Answers
You will need to replace or have the convergence IC's replaced. They are soldered into the printed circuit board. You will need to know how to solder also un-solder on solid state printed circuit boards. If you do not know this, play it safe and call in a pro to assist you in this repair. Good luck
Posted on Feb 11, 2008
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Cropped sides
Change picture size in menu; OR the movie/show you are watching is NOT recorded in widescreen HD?
Apr 01, 2014 | Panasonic VIERA TH-C50HD18 50 in. Plasma...
Black strip in TV
This sounds like a screen driver problem. You will probably need to replace the screen, which can be expensive. It may be better to replace the TV. Ask a repair shop to give you a repair quote.
Jul 25, 2012 | AOC A42HD84 42 in. Plasma HDTV
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Multi colored strip running thru tv
I'm affraid to say that your screen has got a PDP/LCD fault. Just like a tube going on a TV. This is a fault which is beyond economical repair
May 27, 2010 | Toshiba 50HP66 50 in. Plasma Television
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Panasonic PT-53WX42 53" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
